Thread: Shifting into second
Results 1 to 2 of 2
  1. #1 Shifting into second
    Oct 2012
    Minnesota
    2003 Gran Prix, 200,000. Shifting from 1st to 2nd does or does not happen depending on conditions. No problem with any other shifting. I have been having problems for a few months now:
    Air temp 60+ & engine cold -- bad, will not shift into second for maybe quarter of a mile. Once it makes it to 2nd most subsequent shifts from first to second are ok. The more the car warms up the better behaved it is.
    Air temp <50, problem exists but significantly less of a problem.
    Have found that gradual starts from a stop help it catch.
    I took it into a transmission shop and they said the codes indicated my car was a mess, the transmission needed to be replaced and probably was not worth it. Sorry, do not have the codes.
    It occurred to me, when the weather got cold and the transmission started to behave "better", that maybe something else was going on, like a bad temperature sensor and thought I would ask the question before chucking $3000 at the problem.
  2. #2 Re: Shifting into second
    Go get it scanned. Get the codes. Codes for TPS, MAF and MAP will screw with shifting.
  1. Shifting w/o key on?
    By bobabooie in forum General Tech Discussion
    Last Post: 02-21-2011, 08:33 PM
  2. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  3. shifting from first to second
    By zuk7 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-24-2010, 08:09 PM
  4. better shifting?
    By nicksilvergt99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 11:19 PM
  5. Another shifting from CGP
    By gp2000gt in forum Introductions/Noob Questions
    Last Post: 01-28-2008, 04:07 PM
