Thread: Opinions on Dex 6...
Results 41 to 60 of 62
  1. #41
    Ohio
    Your tranny is ****ed then if it's black already
  2. #42 Re: Opinions on Dex 6...
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by 99pgpgt View Post
    racecar! but not helpful. its not BLACK but its got a black undertone
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
    Ohio
    That means a lot of clutch material
  4. #44 Re: Opinions on Dex 6...
    Apr 2012
    Middletown DE
    Oh well, I guess I will be replacing the clutch pads/plates then. It slips into second sometimes. Whomp.
    1993 Oldmobile 88
  5. #45 Re: Opinions on Dex 6...
    Nov 2011
    NY
    Quote Originally Posted by acidcrashdburnd View Post
    Bringing this back from the dead.... Does anyone have a specific brand they use? I used Castrol Dex6 last time and less than 20k on the fluid its black. I want to change it out next week, just dont know what to get.
    Yeah... Use anything but what you used last time... Lol
    Agree if it's black, not good, but do the pan drop and see if there's any bits in there too. Maybe some fresh slippery stuff is just what the doctor ordered. At this point you got nothing to lose, lol.
  6. #46 Re: Opinions on Dex 6...
    I live here. TLSheff's Avatar
    Ya your tranny is FUBAR'd. I would suggest another pan drop and Dex3 with maybe some Lucas additive or w/e the additive is for slipping tranny's and hope like hell it works, but then again I argued this a year ago and I don't know what I'm talking about.
    Ohio
    There is nothing wrong with Castrol dex 6. I've used it for the past year and after the first pan drop after about 15k..it was as red and smelled as fresh as if I just poured it out of the bottle.
  8. #48 Re: Opinions on Dex 6...
    PA
    I use Valvoline because it is full synthetic. I've also used GM stuff from the dealer. IMO, it is more important that you change the fluid regularly than the brand of fluid. But if your fluid is black in that short of time, you probably have clutches wearing and you won't be long before a rebuild is in store.
    2001 GSE
  9. #49 Re: Opinions on Dex 6...
    Apr 2012
    Middletown DE
    Quote Originally Posted by Zef_66 View Post
    Yeah, no surprise that the soft parts are failing. I will just change it out and ride it till it needs an overhaul.
    1993 Oldmobile 88
  10. #50 Re: Opinions on Dex 6...
    Donating Users moddman's Avatar
    Midwest
    h**p://shop.zzperformance.com/store/p/279-Dexron-VI-Transmission-Fluid.aspx
    Use this....Did a shift on my newer trans......Nice shifts. No issues whatsoever. And it is official GM spec fluid.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  11. #51 Re: Opinions on Dex 6...
    LOL, each trans is different to a degree. With a higher mileage trans, I'd say go with whatever you want to and a bottle of Lucas. The Lucas will thicken up the fluid and help seals etc. Also has some form of a friction modifier in it to help the clutches grab. To give you guys an idea though..
    My third and fourth clutches in Bonne were shot at 176 when I had the trans rebuilt. However for the nearly stock level of power I was putting down (pulley, intake and headers) it was sloppy and held fine.
    Even this nearly shot 4th hub was holding.
  12. #52 Re: Opinions on Dex 6...
    Apr 2012
    Middletown DE
    So I noticed that my dipstick said use Dex 3 on it last night. For it being an 05 I was confused. Maybe they just recycled parts on the production line?
    1993 Oldmobile 88
  13. #53 Re: Opinions on Dex 6...
    Or maybe they hadn't come out with Dex 6 yet? Ya Dipstick!
  14. #54 Re: Opinions on Dex 6...
    Ohio
    dex 6 came out in 2005..but, your car being an 05 wouldnt have gotten that yet.
  15. #55 Re: Opinions on Dex 6...
    Quote Originally Posted by moddman View Post
    Or you can just go to a dealer and get 2 Gallons of Dex6 ATF....
    GM# 88861954 for Gallon - Retail $30.89
    GM# 88861037 for Quarts- Retail $ 8.63
    Alot of Dealerships will give a break tho so could be less.
    EDIT: BTW Before anyone says but ZZP sales it cheaper. Add shipping to that. To me shipping is an additional $8.80 on top of the $22.49 its $31.29 per gallon... or you can go to a local Dealership and probably save some money. If you want the AcDelco Dex6
  16. #56 Re: Opinions on Dex 6...
    Ohio
    lol i think my dealer told me like 35 for a gallon -_-
    i could be wrong though.
    go to amazon and order it off them...6 quart box of castrol for 38
    ^ and use prime shipping and get it in 2 days
    04 Comp G.
  18. #58 Re: Opinions on Dex 6...
    Apr 2012
    Middletown DE
    Looked at the door sticker my car is actually a 2004 but was sold as an 05.
    I get it for $21 a jug with my uncles employee discount w/ GM. I am going to look up "do it at home flushing". I read about disconnecting the cooler lines and running the car till it goes dry.. but something about that makes me unsettled.
    1993 Oldmobile 88
  19. #59 Re: Opinions on Dex 6...
    if you fill a 5 gallon bucket with clean new fluid, and have another empty 5 gallon bucket, you can take the lines off and run hoses to the buckets, let one suck up the new fluid and the other to dump the old into. when you see new fluid come out turn the car off, hook it all back up, run it a few minutes, then check and fill as needed.
    if you have air blow out the cooler in the rad.
    i did the method you described with my brother in his Yukon you start the car let it pump till you see bubbles, shut it off, add 4 quarts, do it again, till you see bubbles. repeat till you've gone through 8 quarts or so.
    you need clear tubing to see the bubbles, his lines were bolt on, so we picked up a fitting that had a nipple for the tube, and threaded onto the trans line, it was a neat job too, not much mess wise at all.
  20. #60 Re: Opinions on Dex 6...
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I know of many guys even 4T60's using Dex 6 and reporting better shifts and cooler temps. Seems good. Walmart has a good priced in house brand of it that most are using and like.
    I run this, it's called "Super Tech" and it's great stuff. No problems in either of my vehicles. At the cheaper price, you can afford to change it more often. Meets GM specs, so why not?
    Also, correct me if I'm wrong, but the 4T65E has only minor changes between 03 and 04... so if Dex 6 is fine in the new models, it's probably just fine in the older models. And vice versa. Someone correct me on this if that's not the case.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. Is this really that bad? Need opinions
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-24-2010, 05:29 PM
  2. Need Opinions
    By BwolfGT in forum Off Topic Discussion
    Last Post: 03-28-2010, 09:53 AM
  3. opinions
    By TorqueAutoMotiv in forum Tires & Wheels
    Last Post: 03-26-2010, 12:25 PM
  4. What you think about this GTP, please opinions
    By robahr24 in forum Off Topic Discussion
    Last Post: 02-06-2009, 12:34 PM
  5. Opinions of my Gp Gt
    By gpracing in forum General Tech Discussion
    Last Post: 09-18-2008, 11:22 PM
