I have a 97 GTP with the HD Transmission. 145,000 miles.
My friend works at a shop and they have a tranny flush machine. Should I do the flush from old to new fluid or should I just drop the pan, put in a new filter, and change the gasket?
1. What fluid should I use if I do the full flush?
2. What fluid should I use if I am just dropping the pan and refilling?
3. If I do the full flush, will the new fluid cause slipping due to the fluid not having the metal for friction?
Obvious question number 3 is an opinion.
Thanks,
Tim
