I have been having problems with my TCC solenoid locking up to soon a 40 to 65 causing the motor to lug and knock. So I installed a switch to turn off the TCC solenoid off and It worked great for a while. Then It started back up again with the switch off and is even worse with it on. I am not getting a check engine light and the whole problem started when I changed the transmission fluid to Dexron 6 could this be a problem being a synthetic?
