Thread: TCC solenoid bad?
Results 1 to 2 of 2
  1. #1 TCC solenoid bad?
    SE Level Member rah575554eg's Avatar
    Apr 2009
    Alliance, NE
    I have been having problems with my TCC solenoid locking up to soon a 40 to 65 causing the motor to lug and knock. So I installed a switch to turn off the TCC solenoid off and It worked great for a while. Then It started back up again with the switch off and is even worse with it on. I am not getting a check engine light and the whole problem started when I changed the transmission fluid to Dexron 6 could this be a problem being a synthetic?
    2003 Pontiac Grand Prix GTP 3.2" mps, SSIC, Ported M90, Ported LIM, ported tb, K&N Intake, Headers, 160 stat, AC rapid fire plugs and DHP custom tuned pcm
  2. #2 Re: TCC solenoid bad?
    No it's not a fluid change problem. Likely your trans was having some issues etc before. Dave has a writeup on the common TCC issue. Although it sounds like your trans is going through the gears as quick as it can to help you limp wherever you are going.
    I'm pretty familiar as I'm limping mine at the moment.
    Probably talking bout a rebuild or replace.
  1. tcc solenoid?
    By rah575554eg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2010, 04:26 AM
  2. bbv solenoid
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 06-15-2010, 09:20 PM
  3. boost solenoid
    By tjvdubsport in forum General Tech Discussion
    Last Post: 05-27-2009, 12:24 AM
  4. Epc solenoid help!
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-27-2009, 12:31 PM
  5. bbv solenoid
    By gotboost3 in forum General Tech Discussion
    Last Post: 03-11-2009, 01:42 PM
