Thread: transmission problem
Results 1 to 3 of 3
  1. #1 transmission problem
    ashtabula, ohio
    first off id like to introduce myself. im jamie from ohio, i have an 01 grand prix(actually its my girlfreinds). today on my way home from work i got ran off the road and into a snow bank. i tried rocking the car to get it out and the car just stopped moving, it would rev up but that was it. got towed home and after it sat for a little bit it went into gear again but as soon as it warmed up it wouldnt move again. i havent had time to go thru it and check anything yet, any ideas? thanks in advance.
  2. #2 Re: transmission problem
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Hi Jamie,
    The first thing I would check is the transmission fluid level. This should be to the Full mark on the stick with the engine running and transmission in park range. You could have damaged a cooler line when you went off the road so that is the easiest thing to check. If that is ok then you may have done some damage to your transmission trying to get it out of place and is hard on it trying to push it when its stuck or rock it back and forth.
  3. #3 Re: transmission problem
    ashtabula, ohio
    checked the fluid and it looked like oil so im gonna drain it and change the filter and hopefully thatll do it.
  1. Transmission Problem
    By cbeach in forum Introductions/Noob Questions
    Last Post: 12-30-2010, 08:23 PM
  2. Transmission problem?
    By The LoKi in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 12-19-2010, 02:43 PM
  3. Transmission problem
    By lhssnowman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2009, 03:38 PM
  4. Transmission problem(s)
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2009, 06:34 PM
  5. Odd transmission problem
    By ihartmacz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2009, 12:43 AM
