Thread: trans dont shift right
Results 1 to 6 of 6
  1. #1 trans dont shift right
    Feb 2010
    Flint Michigan
    Im looking at buying a new gtp, its a 1998 gtp the problem is that when floored the car revs to 4,500 rmp and stays, it will not shift until you let off the gas. The car drives decent While driving normal, but when you floor it, the car will not shift no matter what, until you let off the gas. You can let off the gas just a little bit and it will shift.
    I asked the guy whats wrong and he told me the trans is out of a chevy venture van. he does not know why it is doing this.
    would using a venture van transmission cause the problem it having? Or could it be something else? what should i look for.
    how can it be fixed.
  2. #2 Re: trans dont shift right
    Akron Ohio
    Id stay away from that!
  3. #3 Re: trans dont shift right
    Feb 2010
    Flint Michigan
    Explane why
  4. #4 Re: trans dont shift right
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    Quote Originally Posted by monsterjam5000 View Post
    Explane why
    That's why. Not worth the trouble to switch it back to a GP trans unless you can score it for like 300.
  5. #5 Re: trans dont shift right
    Try and scan it for codes. I'm thinking it probably is a different gear ratio and the pcm is having trouble working with the incorrect ratio.
  6. #6 Re: trans dont shift right
    Feb 2010
    Flint Michigan
    ya it says ventures have the 3.29 gear ratio, that would be cool if thats all thats wrong.
    ill have it checked and if so ill order a after market tune thats tuned for the 3.29 gear ratio. car should have a little more peep of the line.
    who would be able to check the codes for me?
  1. trans coolier/shift problem
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-24-2010, 09:50 PM
  2. GTP Trans won't shift to 4th after hill
    By SliceTheRice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-11-2010, 10:37 AM
  3. Trans does not want to shift out of 1st until warm
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 11:45 AM
  4. What Trans Shift Points should I use?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-25-2008, 08:04 PM
  5. Does the trans need to be dropped to swap out shift solenoids?
    By bminior in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-08-2008, 08:59 AM
