Thread: No Overdrive/4th gear...need help
Results 1 to 16 of 16
  1. #1 No Overdrive/4th gear...need help
    Arizona
    2000 GTP with 115k miles, I just bought it. It had no overdirve and a tranny shutter. I did a service on the trans. Filter and fluid plus a lil Lucas and still no OD. It shifts under power just fine, Anyone have an idea as to what might be going on?
  2. #2 Re: No Overdrive/4th gear...need help
    Charles City, IA
    If you would have tried a search, you would have found that your 4th clutch hub is stripped, you need a new trans or a rebuild.
    SMGPFC Two Nipple General
  3. #3 Re: No Overdrive/4th gear...need help
    Feb 2008
    Yeah, you bought a car without 4th, you will need a new tranny for sure.
  4. #4 Re: No Overdrive/4th gear...need help
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Any DTC codes? Some codes inhibit 4th gear, doesn't necessarily mean your 4th clutch shaft is ruined.
  5. #5 Re: No Overdrive/4th gear...need help
    Yes..and being in AridZona.. you may have a couple local buddies of mine near you. One does work on transmissions. To swap out a 4th hub shaft (if that's the issue) isn't bad with the trans in the car.
  6. #6 Re: No Overdrive/4th gear...need help
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    You don't need a whole new trans... just the 4th gear clutch shaft. Pick up a Hardened one from ZZP for like $80, then gaskets, then some fluid and swap out the shaft, can be done with the trans still in the car..
    My 4th has been gone for over a year now.. i just drive it like that haha.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  7. #7 Re: No Overdrive/4th gear...need help
    Quote Originally Posted by BoostenGTP02 View Post
    Gas mileage FTL. Plus your transmission is getting pretty hot running those high RPMs. I'd just get it fixed!
  8. #8 Re: No Overdrive/4th gear...need help
    Arizona
    No DTC codes, computer is telling the trans to shift and the lockout is working properly but yet no 4th gear. Looks like i will be giving it a new 4th gear. Thanks you all for your input as to I am new to the GTP group. Only one regret; I DIDNT BUY ONE EARLIER!!! even without 4th gear, a very fun car to drive!
  9. #9 Re: No Overdrive/4th gear...need help
    FWIW ZZP is very overpriced on the shaft.
    TEP has them cheaper and sometimes you can find a name your price on ebay. I've gotten a couple for $45 shipped.
  10. #10 Re: No Overdrive/4th gear...need help
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Also if your not comfortable doing the work yourlsef let Bill know hes very reputable on here and can hook you up with one of his buddies
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  11. #11 Re: No Overdrive/4th gear...need help
    Quote Originally Posted by tayl5645 View Post
    Already tossed him a pm with how to get in touch with a good guy in Phoenix.
  12. #12 Re: No Overdrive/4th gear...need help
    Arizona
    to the op, the guy in az is good, you can trust him with your car..
    '00 GT- nothing special
  13. #13 Re: No Overdrive/4th gear...need help
    Corey...next time you see Bob, tell him Majestic Teal is a girlie color.
    Yeah..Thomas is the man.
  14. #14 Re: No Overdrive/4th gear...need help
    Arizona
    i will, but he barely comes around though, ive only met him once
  15. #15 Re: No Overdrive/4th gear...need help
    Jul 2010
    Michigan
    Majestic teal?? Sounds kinda ehhh
    2005 GTP Grey
  16. #16 Re: No Overdrive/4th gear...need help
    Last off topic post. It's a color Gm used for 1 year on bonneville, and I think GP's too. In sun it'll look green, dusk...and it's purple then teal .. it's a cool color. But busting a buddies chops is always in order.
  1. overdrive
    By BOOSTED GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2011, 12:03 PM
  2. On-and-off overdrive...
    By Hogrydr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2010, 11:32 PM
  3. Tranny shifts from 2nd gear to Overdrive?!?!?
    By atrainbynight in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2009, 04:14 PM
  4. No overdrive
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2009, 02:31 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
