Thread: Recommended Upgrades to handle v8
Results 1 to 10 of 10
  1. #1 Recommended Upgrades to handle v8
    SE Level Member Snapperhead's Avatar
    Dec 2010
    Michigan
    Hello looking for advise on 4t65e upgrades to handle the load of a 550hp 5.7 V8. This is in a Fiero not a GP but I thought I would come to a land who knows the beast the best. This winter I will be swaping over from a manual trans to the 4t65e for a more stable platform. Thanks for any help and advise, oh it does have an adapter plate so it is on the correct bolt pattern.
    I did post this in the introductions forum as that was all the system would allow me to post in on the first post.
  2. #2 Re: Recommended Upgrades to handle v8
    hardened everything.
    1" chain....
    If you cant find one, get a different transmission.
    That is all.
  3. #3 Re: Recommended Upgrades to handle v8
    Jan 1970
    Maquoketa, Iowa
    If the car was maybe 2500lb-3000lbs, you might get away with a 7/8ths chain. The 1" chain is hard to find, expensive and only comes in 3.29 ratio. The 7/8ths chain you can find in much more ratios for your needs, if anything, you may want to check the chain for stretching every so often.
    Your probably going to want the tranny to shift pretty hard as well, so your probably going to need to be able to bump up the line pressures on the trans in the pcm and on the trans itself. Probably going to need a steel channel plate gasket to handle that.
    Is the car N/A, s/c or turbo? There are torque converters zzp sells, but you may want to go with a custom converter.
    300m input shaft, hardened output shaft and pump shaft. Most transmission builds of the 4t65e don't last very long when built by someone else not experienced with this type of trans. We have zzp, triple edge performance, tim king at intense racing and a few other shops around the U.S. that do excellent work on the 4t65e's.
  4. #4 Re: Recommended Upgrades to handle v8
    I'd get one from Dave @ Triple Edge Performance...I love mine and beat the snot out of it...he's a great guy, does awesome work...and its very resonably priced for what goes into them.
  5. #5 Re: Recommended Upgrades to handle v8
    Jul 2008
    sumter,south carolina
    I'd get one from Dave @ Triple Edge Performance...I love mine and beat the snot out of it...he's a great guy, does awesome work...and its very reasonably priced for what goes into them.
    X2 .. dave has GREAT customer service and his work is top notch.
    heres his link Triple Edge Performance - Home Page
    fixed your typo too nick its reasonably.. not resonably.
    02 GTP with mods 05 GP for DD
  6. #6 Re: Recommended Upgrades to handle v8
    Dec 2010
    Huntington, California, USA
    Quote Originally Posted by Snapperhead View Post
    This is in a Fiero not a auto parts transmissions but I thought I would come to a land who knows the beast the best.
    I think this will be the beast of the best! LOL
  7. #7 Re: Recommended Upgrades to handle v8
    Akron Ohio
    3X go to Dave
  8. #8 Re: Recommended Upgrades to handle v8
    Dec 2010
    Michigan
    Quote Originally Posted by FoSHO99 View Post
    Thanks for the tips. The car is about 2700lbs, engine is n/a, no s/c or turbo. I may run a bottle if I ever get a trans to hold. Dont plan for more than 600hp about 450 now and may do a 383 stroke in a few years.
    Zzp is about a ten minute drive for me, I was planning to do the trans build myself however I've been really busy and never been inside the 4t65e. Best be smart and just sublet it over to zzp.
    Does the 4t65e have a sweet year to use? h/d or not?
    I will be using a stand alone controller to run the trans... fill me in if you a recommendaton, I was thinking the pcs unit.
    Thanks,
  9. #9 Re: Recommended Upgrades to handle v8
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    2003 Plus are considered stronger
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: Recommended Upgrades to handle v8
    Jul 2008
    what gear ratio are u planning?
  1. subwoofer box smaller than recommended?
    By Breen in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2010, 02:11 PM
  2. FWI: recommended tube size for FWI?
    By JoRoW99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2010, 03:51 PM
  3. Recommended Product Brands
    By Clar2478 in forum Detailing Tips and Tricks
    Last Post: 11-19-2009, 10:22 PM
  4. what is the recommended spark plug for a 01 gtp
    By 98gtp1000 in forum General Tech Discussion
    Last Post: 02-22-2009, 08:28 AM
  5. Recommended Trans Fluid
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-20-2008, 05:57 PM
