Thread: Trans isue on a '98 GP
Results 1 to 6 of 6
  1. #1 Trans isue on a '98 GP
    Dec 2010
    New Jersey
    Car bucks after driving around 1 hour (mostly highway). I pull over, turn the ignition off, wait 2-3 minutes, and drive away. Recently, check engine lisght is coming on. Mechanic put it on the scope, and it threw a trans torque converter error.
    Anyone with similar experiences? I don't really want to shell out $2500 for a new trans (car KBBs at around $2700).
  2. #2 Re: Trans isue on a '98 GP
    There is some common info about the TCC codes etc on Dave's site. Tripleedgeperformance.com. Check it out and tell us if that's what you are finding.
  3. #3 Re: Trans isue on a '98 GP
    Dec 2010
    New Jersey
    Will do...Gotta get the mechanics paperwork to find the code(s) he pulled...
  4. #4 Re: Trans isue on a '98 GP
    Dec 2010
    New Jersey
    Ok, it's a PO742 TCC Stuck On. I tend to think it's #3, just becuase it does go away if I stop and start.
    How much/what kind of work is involved in a solenoid replacement? Anyone have any experience in resolving this issue?
    3. This problem can be a hydraulic problem. This is the most common cause of this code that I have found and stems back to a clogged TCC solenoid, not because it failed. Excessive debris in the transmission or a failing torque converter lockup clutch can cause the solenoid to have debris stuck inside and this causes a restriction in fluid flow through the solenoid. If the solenoid can not bleed off the pressure the TCC can be stuck on. If the wrong TCC solenoid is installed during an overhaul this problem can also arise as a late 4L60E solenoid is identical but does not operate the same and acts like a clogged solenoid. As mentioned in problem #1 a stuck TCC apply valve is a physical problem but causes a hydraulic problem because the fluid pressure will not properly bleed off because the valve is stuck in the wrong position instead of being able to move freely in the bore of the valve body.
  5. #5 Re: Trans isue on a '98 GP
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Most times when code P0742 pops up it is from the torque converter clutch coming apart and the debris clogs the solenoid and restricts flow. You could try replacing the solenoid but the problem will likely come back as the damage is done. Something you could check first is to drop the pan and remove the filter and cut it open. If you see a lot of find debris in the pan and or inside the filter and it is dark in color or there is lots of fine metal shavings you can pretty much count on replacing the trans.
  6. #6 Re: Trans isue on a '98 GP
    Dec 2010
    New Jersey
    Ok...there were a bunch of issues...TCC solenoid, pulse solenoid controller, Torque converter...hell, they even had to replace a tranny mount!
    All told, it was a bit over $1200...1/2 a new trans. I've taken it on several extended trips (over 1 hour drive time, varying speeds, etc.), and it runs as smooth as a baby's butt! Keep yer fingers crossed...
    Thanks for the help, guys! You all pointed me in the right direction!
  1. gtp vs 85 trans am
    By bballa0740 in forum Track Sessions and Kills
    Last Post: 07-15-2010, 12:50 AM
  2. What Trans to buy?
    By sc3800fiero in forum Off Topic Discussion
    Last Post: 03-21-2010, 12:20 PM
  3. gtp trans is out
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-03-2009, 04:29 AM
  4. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  5. 06 trans in a 99 gt?
    By bronzemist99GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2008, 01:52 AM
