has anyone just change the epc or had it change and it fixed the problem with the hard shifting when the trans gets hot? how hard is it to take the side cover off without completly removing the trans? money is tight every trans shop wants to rebuild. other then that problem the trans is fine. i emailed the trannyman he says it a 50-50 chance that it could fix the problem due to the mileage he says i can try replacing the epc and maybe installing a transgo shift kit. just trying to see what others have done ? thank for ant input
