Thread: P0740 whats this mean for the GP?
Results 1 to 3 of 3
  1. #1 P0740 whats this mean for the GP?
    May 2008
    iowa
    So my car will not shift outta second gear every once in a while until i shut it off and start it back up. I stopped at Advanced Auto and had it scanned and came back with the code P0740 torque converter clutch malfunction. Im a member over on Grandprix.net and was referred to here hoping to here from the all might trannyman. All input is appreciated.
  2. #2 Re: P0740 whats this mean for the GP?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    That is a tranny code.
    Tq convert clutch malfunction.
    My friend you are on your way to a rebuild.
    If your lucky it is a short in the wiring harness and you can replace. Might as well do an overhaul
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: P0740 whats this mean for the GP?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    P0740 will set if the pcm detects either a short to ground or ignition voltage on the TCC apply wire when not commanded. Check all of your fuses first to make sure you dont have a bad fuse, there should be one for TCC which is a feed wire off of the brake pedal switch. Not shifting out of second shouldnt really have anything to do with this code but if you have a pcm going bad or some bad grounds then that could explain both problems.
  1. whats wrong with the se?
    By blazedgp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2008, 09:20 AM
  2. Whats up
    By jonpratt77 in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:27 PM
  3. Whats your air filter?
    By Smokedgtp in forum Turbo
    Last Post: 05-01-2008, 05:24 PM
  4. Whats Up?
    By Dizave in forum Introductions/Noob Questions
    Last Post: 01-28-2008, 04:10 PM
