Thread: On-and-off overdrive...
Results 1 to 4 of 4
  1. #1 On-and-off overdrive...
    WI
    The car is a '97 GT with 110K that has been pretty much sitting for the last year or so. Now, OD is working some of the time, mostly when cold. When it warms up, it might work, might not. If the clutch hub splines were gone, I'm assuming it wouldn't shift into OD at all. Is there a solenoid that controls the OD? Anywhere else I should be looking? Thanks for any help.
  2. #2 Re: On-and-off overdrive...
    WI
    As long as we're at it, a couple of other questions too. The shifter won't shift out of park without putting a screwdriver in the slot on the console and the ignition switch sometimes sticks so I can't get the key out. Are the 2 related? Cable adjustment? Thanks again.
  3. #3 Re: On-and-off overdrive...
    Greenville, SC
    Quote Originally Posted by Hogrydr View Post
    I have the same problem, if I had the time I would try adjusting the cable. The ignition switch is designed to not let u take your key out until u are in park. They are related. Sometimes when i shove the **** out of it into park it will let my key slide right on out.
  4. #4 Re: On-and-off overdrive...
    Waukesha, WI
    my GT did that too after my accident, if you take the counsel apart theres a white plastic arm that gets pushed down with the screwdriver, take a zip tie and hold it down. the only down side is you can pull the shifter into drive without putting your foot on the brake
  1. Overdrive problems...
    By Chris in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2011, 11:11 PM
  2. 2000 gp gt no overdrive
    By My Custom S in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2010, 01:02 PM
  3. '98 WON'T go into OVERDRIVE
    By jdkopveiler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2009, 11:52 AM
  4. No overdrive
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2009, 02:31 AM
  5. Overdrive Problem (does not seem to be one)
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 10:02 AM
