Thread: transmission fluid
Results 1 to 5 of 5
  1. #1 transmission fluid
    Plainfield
    I am just asking a question and getting suggestions?
    I just purchased a 2002 grand prix GT and the car is running like a raped ape , but the transmission fluid has never been changed on it and it has 88000 miles on it. Would you change the fluid or no?
    i believe that i should but i want to get some other input from others.
    the last time i changed the transmission in my car i had to put a new trans in it and it cost me 1500.00
    the fluid has a tint of red to it , i mean it is not exactly red if you know what i mean .
    thanks
  2. #2 Re: transmission fluid
    Willoughby, Ohio
    every 50k miles i believe is recommended to change, if you are having no problems and the fluid is a good color and doesnt smell burnt you should be ok tho, i would still change it
  3. #3 Re: transmission fluid
    100 K miles is what it says in the owners manual....
    I'd drop the pan, change the filter and fill it with dextron VI.
  4. #4 Re: transmission fluid
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by dave2002GP View Post
    thanks
    Changing your fluid has nothing to do with it going bad. I still can’t believe so many ppl think denial is a river in Egypt. What happens is ppl neglect/beat the piss out their tranny and only when it starts to act up try to take the cheap road out and hope it just needs a fluid change. The only thing you need to worry about is checking the fluid level first thing once you get it done. Not when you get home or at the gas station, as soon as you get it serviced. What happens is ppl mess up the “flushing” procedure and short fill them now and then.
    Now is the perfect time to change your fluid, I personally recommend 75k to my friends.
    Tranny fluid is red, so good observation there.
    And for sure use Dexron 6, it is very good stuff. It is worth every extra penny.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: transmission fluid
    let's toast til we die brand121's Avatar
    South Carolina
    I try to do mine every 75k, give or take a few miles... My gp has 232k miles on it and for the last four years, I have been running Hurst Hot Shift Trans fluid in it. It has extra friction modifiers in it and my tranny still shifts like it's new.
  1. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  2. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
  3. Finding Transmission Fluid
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2009, 12:08 PM
  4. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
  5. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
