Thread: 01 GTP - No 1st Gear
Results 1 to 8 of 8
  1. #1 01 GTP - No 1st Gear
    Plymouth
    A couple hours of being parked after running fine, I got in and shifted into Drive with nothing, manually shifted into 3rd with nothing, but manually shifting into 2nd,1st and reverse worked. Accelerating in either 1st or 2nd, the tranny would shake pretty bad with just a touch of the pedal. The car has 93k and the only signs of problems were every 2-3 months, I'd put it into Drive and it would take maybe a second to engage in 1st but no real problems what so ever. Any help would be much appreciated.
  2. #2 Re: 01 GTP - No 1st Gear
    HUDSON
    Obvously there seems to be a problem with the transmission.
    Time to get it rebuilt, and install a new trq. converter.
  3. #3 Re: 01 GTP - No 1st Gear
    you mgiht be able to like un hook the battery and some connecter and let it sit for a long while and then hook it all back up and it should reset the computers and such.
    I think there is a thread about it somewhere.
  4. #4 Re: 01 GTP - No 1st Gear
    Plymouth
    Anyone know what connector he might be talking about in the last post?
  5. #5 Re: 01 GTP - No 1st Gear
    i wish i could find the thread, but i am not able to find it on here, but im pretty sure they unplugged the battery and something else to try and reset the computers.
  6. #6 Re: 01 GTP - No 1st Gear
    n/a
    The forward drive band is broken. You need to pull the transmission and rebuild it. Sorry man.
  7. #7 Re: 01 GTP - No 1st Gear
    Plymouth
    Any recommendations on where to get a good rebuilt transmission? GTP is all stock.
  8. #8 Re: 01 GTP - No 1st Gear
    Akron Ohio
  1. no first gear what gives
    By blacksleeper in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2010, 07:49 PM
  2. rev gear bad.
    By clevelandfan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-05-2010, 12:48 AM
  3. 4th gear gone, why?
    By Lowizle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2010, 05:55 PM
  4. top gear
    By 1999gt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-07-2009, 08:54 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
