Thread: Transmission acting weird during startup
Results 1 to 6 of 6
  1. #1 Transmission acting weird during startup
    utah
    So when I crank the car it starts perfect...When I shift into Reverse it feels like there is no pressure, but if I give it gas it goes in reverse no problem...When i shift from reverse into drive The RPMs go up to around 1200 (from 900) and the car wants to pull without any gas...It only does this when its a cold start...I just had this tranny rebuilt a year ago, and the fluid is still nice and bright red (and filled to a good level). I took it to the shop and they said there is nothing wrong, but I figured id ask some advice from you guys.
  2. #2 Re: Transmission acting weird during startup
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    dont quote me on this but i had a guy come into the store one time and said he had weird shifting issues and it ended up being his throttle position sensor. do you have a ses light?
    2000 Daytona GTP(aka the slow fwd GTO)
  3. #3 Re: Transmission acting weird during startup
    Feb 2010
    Connecticut
    thought i would put my 2 cents in on this one... my car does the same thing minus me having to give it some throttle to get it into reverse. I was told to check the IAC on the throttle body and clean it. I plan on doing this later tonight. Ill let you know if this solves the problem
  4. #4 Re: Transmission acting weird during startup
    Jul 2008
    sumter,south carolina
    possible vac leak, if ur boosted start with rubber T under snout and trace ur way around all the vac lines... my rubber T being disconnected caused several codes and funny trans shifts.
    02 GTP with mods 05 GP for DD
  5. #5 Re: Transmission acting weird during startup
    It would help if we knew what you drove. Some 97's have a vacuum controlled trans, but most of the cars have an electronically controlled trans.
  6. #6 Re: Transmission acting weird during startup
    SE Level Member X97prixX's Avatar
    Idaho
    I'm having the same problem Having to give it gas to get it to shift into reverse from a cold start. It's actually freaked me out.
  1. P0140 code and boost gauge acting weird
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-14-2009, 07:50 AM
  2. Grand Prix acting funny at stoplights and weird accel help
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-27-2009, 08:24 AM
  3. please help tranny acting weird
    By ryan88z in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 09:17 PM
  4. Forums Acting Weird
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-29-2008, 08:03 AM
  5. Help please!!! Electrical system acting weird, Car won't start now!!
    By Tkuligowski in forum General Tech Discussion
    Last Post: 01-24-2008, 08:42 PM
