hey guys new to forum and i have a small problem. I have a growling noise coming from the front end . I thought is was a wheel bearing but they seem tight so I investigated a little further and it seems there is alot of play where the drivers side axel goes onto the output shaft. if you pull the axel out the shaft has a lot of play. the noise is steady and increases with vehicle speed . it also does it with the trans in neutral. this leads me to believe that its a bad output shaft bearing ,but I can not find any listing for one any where . the car is a 2002 grand prix gt with 120k I did notice they list them for 99 and older but not for anything newer .any help would be awesome
