Thread: no 1st gear, trans shop says it's pcm
Results 1 to 10 of 10
  1. #1 no 1st gear, trans shop says it's pcm
    GT Level Member jdmgtp's Avatar
    MI
    well they finally got my trans back together. Problem is, when you put the trans in drive it starts off in 2nd gear. They think it's the pcm since when they command 1st gear with their computer controller it goes into 1st gear. They're telling me in need a new computer. I'm going to try a reflash 1st. Anybody have any idea what would cause that other than a pcm?
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  2. #2 Re: no 1st gear, trans shop says it's pcm
    Outer Space
    I think they are full of it and blaming "your mods". Flash it back to stock and see if it does it then.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: no 1st gear, trans shop says it's pcm
    SE Level Member Nsane's Avatar
    Feb 2010
    Rochester,NY
    did you change the gear ratio of your tranny?
  4. #4 Re: no 1st gear, trans shop says it's pcm
    MI
    actually I just did a "write entire" and it works now.....
  5. #5 Re: no 1st gear, trans shop says it's pcm
    MI
    Let me just take a second to say something about Dave at TEP. He is a GREAT guy. I called him and told him the situation, he took the time to talk to me about the problem and even gave me advice. Didn't even seem to mind but happy to help. I would recommend him to anybody.
  6. #6 Re: no 1st gear, trans shop says it's pcm
    Puerto Rico
    I have a similar problem, so what you're saying is I need a new pcm or can the one I have be sent in for a reflash (currently stock). If so who would you guys recommend.
  7. #7 Re: no 1st gear, trans shop says it's pcm
    MI
    a reflash will should do it.
  8. #8 Re: no 1st gear, trans shop says it's pcm
    Outer Space
    If you need a reflash let us know...many of us have tuners.
  9. #9 Re: no 1st gear, trans shop says it's pcm
    Puerto Rico
    I sure would love the help, but unless someone with the tuner lives here in Puerto Rico, its shipping time. I was thinking of maybe doing an upgrade to the pcm. What do you guys recommend? I looked at intense and think their standard level should do.
  10. #10 Re: no 1st gear, trans shop says it's pcm
    MI
    can anybody answer my other post?
  1. Trans hangs in 2nd gear
    By singularity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-29-2009, 11:42 AM
  2. Does Trannyman have a Shop?
    By Sonny in forum Shops and Community Heroes
    Last Post: 10-02-2009, 01:58 PM
  3. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
  4. wel its in the shop
    By boredout in forum General Tech Discussion
    Last Post: 07-27-2008, 08:13 PM
