Thread: 3k stall problem, is it tuning related?
Results 1 to 8 of 8
  1. #1 3k stall problem, is it tuning related?
    SE Level Member Biggie's Avatar
    Williston, ND
    When Im at like 60% throttle and it shifts, afterwards the car stays at like 2800-3000 rpms for maybe a second or two and then it gets past 3k rpms and just takes off. Is it normal? Or is this because of the 3k stall and not having anything adjusted in the PCM? If this is the case, what should I change? I can get video of the problem if necessary. This is my first built up transmission so I'm weery about it.
    I also have a loud scratching/screeching noise at low rpms (like from a stop, stopping for a stoplight, or going around a slow corner). Im gonna take a look at the brakes because it sounds to be coming from there. But it could also be the transmission, it's hard to tell. It doesn't do it when it's stopped so it leads to me brakes, and my pads are pretty worn. The transmission fluid is full as well.
    All help is appreciated.
    XP, Ported: Heads, Blower, 3.0, 42lb Inj., Pacesetters, JP Double Roller Timing Chain, 105 Springs, 3" Exhaust, 3.5" Intake, AL 103s, Powertuner, AEM WB, Input Shaft, 7/8th Chain, 3k Stall, ZZP Pump Shaft + more stuff.
  2. #2 Re: 3k stall problem, is it tuning related?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    What exactly do you mean that it drops to 2800-3000 rpm and then takes off? I guess I am not seeing the problem here as the rpms are going to drop to that after a shift. Is there a bog or power loss feeling after each shift? The rpms dont really say a whole lot if there is an issue. Most guys turn up the TCC apply speed tables in the pcm when going to a higher stall speed than stock. Do you have any trans codes in the pcm since the install? Did you change gear ratio and not adjust the pcm?
  3. #3 Re: 3k stall problem, is it tuning related?
    Williston, ND
    I guess it's more like a bogging. No transmission codes and I kept the same gear ratio. How much should I up the tables?
  4. #4 Re: 3k stall problem, is it tuning related?
    Fort Wayne, IN
    Changing the lockup tables is more personal preference than anything but most guys turn it off completely in 3rd and set it up in the 50mph range in 4th, but its up to you. That doesnt sound like your problem and I know what you are referring to. Do you have a scan while this is happening? What does timing and fuel do when this happens? It is more or a torque management issue and power loss from what it sounds like than a trans issue.
  5. #5 Re: 3k stall problem, is it tuning related?
    Williston, ND
    I'll get a scan today.
  6. #6 Re: 3k stall problem, is it tuning related?
    Williston, ND
    Here is the scan.
    transmissionscan from biggie -- Scan Depot dot net
    I noticed the timing drops to 0 and below.
    Here is a video of it happening.
    tachnotiming.flv - Video - Photobucket - Video and Image Hosting
    THANKS!
  7. #7 Re: 3k stall problem, is it tuning related?
    Williston, ND
    Any idea?
  8. #8 Re: 3k stall problem, is it tuning related?
    Williston, ND
    I went back to one of my really old tunes and it has fixed the problem. Time to get this thing tuned in as the race season is only a few weeks away!
  1. Tuning for the turbo
    By TurboKent in forum Turbo
    Last Post: 05-27-2008, 10:33 PM
  2. GP Wants To Stall
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2008, 07:41 AM
  3. tuning high MPH
    By deangtp in forum PCM Tuning
    Last Post: 04-17-2008, 07:43 PM
  4. Tuning Questions
    By GPSEWidow in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-11-2008, 01:06 AM
  5. a little afc 2.2 tuning help?
    By Bio248 in forum PCM Tuning
    Last Post: 02-24-2008, 12:47 PM
