Thread: Axle replacement, DIY?
Results 1 to 8 of 8
Poil336 Axle replacement, DIY? 07-01-2010, 08:36 PM
FoSHO99 Re: Axle replacement, DIY? 07-01-2010, 09:40 PM
Poil336 Re: Axle replacement, DIY? 07-01-2010, 11:41 PM
Ibwrong Re: Axle replacement, DIY? 07-02-2010, 09:34 AM
Ibwrong Re: Axle replacement, DIY? 07-02-2010, 09:37 AM
Poil336 Re: Axle replacement, DIY? 07-02-2010, 06:45 PM
TheOtherNick Re: Axle replacement, DIY? 07-02-2010, 06:50 PM
Poil336 Re: Axle replacement, DIY? 07-02-2010, 11:03 PM
  1. #1 Axle replacement, DIY?
    Troy OH
    so i started having an obnoxiously loud squeak coming from my driver's side axle assembly today on my way home from work. it sounds like it's coming from the axle boot closer to the transmission. the half shaft itself seemed to be revolving as well, instead of just rotating. it's definitely not brakes, i had the pads out and it was still squeaking. the entire axle is like $50 so i was thinking about replacing the whole thing, as it seems there's no real way around it anyways.
    so, in the interest of saving money, is there anyway to do it at my house and not pay a mechanic? or possibly any other part that could be bad? i was thinking maybe bearings, but like i said, it really doesn't sound like it's coming from the hub.
  2. #2 Re: Axle replacement, DIY?
    Jan 1970
    Maquoketa, Iowa
  3. #3 Re: Axle replacement, DIY?
    Troy OH
    dude. kick ass. i swear i searched. you'd think the search words "CV axle" would bring up that thread.
  4. #4 Re: Axle replacement, DIY?
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Save yourself alot of time by renting the CV axle removal tool. Get mine out in under 3 minutes now after everything is tore apart.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  5. #5 Re: Axle replacement, DIY?
    Oklahoma City
    Looks like this :
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  6. #6 Re: Axle replacement, DIY?
    Troy OH
    that looks useful lol. i sprayed a bunch of wd-40 up in it last night and the squeaking stopped. i'll probably still replace it but it might be able to wait a paycheck or two, what do you guys think?
  7. #7 Re: Axle replacement, DIY?
    Charles City, IA
    IN the boot? I would change it asap, if there is no grease in the boot you do not know when it will finally go, when it does your car will not move because all the power will go to the wheel with less resistance. A prybar also works good for popping the axles out.
    SMGPFC Two Nipple General
  8. #8 Re: Axle replacement, DIY?
    Troy OH
    more like where it goes into what i'm assuming is the transmission. i'll probably order it soon anyways, might as well not put it off. i need a couple valves to rebuild a head off of another motor too, no use paying shipping twice
  1. Axle Seal Replacement [*]
    By Metallistar in forum How To Write-Ups/Tech Tips
    Last Post: 01-21-2012, 09:25 PM
  2. Axle replacement.
    By DnaProdigy in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2009, 09:28 PM
  3. CV Axle questions
    By I4NI in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 01:45 PM
  4. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
  5. Passenger Side Axle Seal Replacement
    By Rob3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 04:35 PM
