Thread: trans cooler?
Results 1 to 9 of 9
  1. #1 trans cooler?
    richmond
    i was wondering what kind of trans cooler is the best for the cheapest price and what kind of changes would i have to make to my exsisting trans lines. any help.... anyone??????
  2. #2 Re: trans cooler?
  3. #3 Re: trans cooler?
    Jul 2008
    sumter,south carolina
    anything to reduce heat on a tranny is a good thing. i ordered a hayden trans cooler from Triple Edge Performance - Home Page was like 50 bucks shipped... theres nicer ones out there like desert fox and a few others i cant remember the name of. with the hayden, its simple... bypass radiator cooling with rubber hoses they send u... however i had to go buy some more hose from autozone... really simple install.
    02 GTP with mods 05 GP for DD
  4. #4 Re: trans cooler?
    New York
    Correct-rule of thumb is that for every 20 degrees you drop the tranny fluid temp, you double the life of the fluid (I don't buy that exactly) but the 4t65E's run real hot and are pretty crappy in stock form so anything that you can do do lower the tranny fluid temperature will greatly increase the longevity of the tranny. I would run the biggest GVW cooler that you can fit in the grille without running the tranny lines through the radiator at all. Long Double stack coolers (not traditional tube and fin which are not nearly as efficient) are about $60 for a 28,000 GVW cooler. Cheapest investment you can make in your transmission. All the GM w body cars should have them and if they did there would not be anywhere near the number of tranny failures-years of experience!
  5. #5 Re: trans cooler?
    ...why (again)? mine never ran really hot, even when beating on it heavily over a good period of time.
  6. #6 Re: trans cooler?
    150* isnt that hot
  7. #7 Re: trans cooler?
    GT Level Member TurboKent's Avatar
    Woodward, OK
    I was hitting 230+ before my cooler. Big part of it is what size stall your running, I have the 3250.
    2003 Grand Prix turbo intercooled
  8. #8 Re: trans cooler?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    X2^^^^
  9. #9 Re: trans cooler?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    150 is great!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. trans cooler with hose clamps FTL!!!!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-24-2009, 03:10 PM
  2. Desert fox trans cooler kit uses B&M rad?
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-21-2009, 12:53 AM
  3. Hayden trans cooler?
    Last Post: 07-16-2009, 01:04 AM
  4. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
  5. GM aux trans cooler
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:32 AM
