Thread: transmission went out on me with no warning.
Results 1 to 2 of 2
  1. #1 transmission went out on me with no warning.
    miami
    i have a automatic 1999 gtp. i had my transmission go out on me 2wks ago with no warning. i can put in reverse and reverse fine. it does nothing in drive. however i can drive it by putting into 1 then shifting to 2 and so on. ive been told to check the torque converter and maybe something electrical with the transmission. any help would be appreciated. does anybody have a idea or thought on what i should look into.
  2. #2 Re: transmission went out on me with no warning.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The forward band let go. Dropping the shifter down into 1 will engage the manual 2-1 band, which is why you can move that way. You're looking at a rebuild or replacement, since getting to that band requires disassembling the entire transmission.
    2001 Buick Regal LS - Almost Stock
  1. warning light
    By theextreem in forum Shops and Community Heroes
    Last Post: 03-06-2010, 02:01 PM
  2. Warning: You may ROFLMFAO
    By KawaFord in forum Off Topic Discussion
    Last Post: 11-10-2009, 02:52 AM
  3. Storm Warning
    Last Post: 02-13-2009, 10:55 PM
  4. ABS warning light
    By BankRupt in forum General Tech Discussion
    Last Post: 07-15-2008, 12:48 AM
  5. Tornado Warning!!!!!
    By 3800SE in forum Off Topic Discussion
    Last Post: 03-07-2008, 08:21 PM
