Thread: tranny leaking.....
Results 1 to 4 of 4
  1. #1 tranny leaking.....
    SE Level Member badgtp2000's Avatar
    Feb 2008
    Canton, NC
    bottom of the tranny, the little cover that covers the teeth of the flexplate....I have fluid pouring out from there.....front pump shaft seal? the torque converter itself? It gave no signs of failing, and as long as there is tranny fluid in, it runs and shifts fine....what ya think? Thanks for the help.
  2. #2 Re: tranny leaking.....
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    There are a few causes for a leak to be here in the severity of yours and is likely the front seal leaking, but not because the seal is bad. The seal can blow out if you stall the car up at heavy throttle for an extended period of time. I have also seen the bushing on the inside of the torque converter that rides on the stator support shaft destroyed which causes the converter to sag on the seal and leak badly. One time, and this will be very rare, a weld on the torque converter was cracked and leaked only when the car was running. Either way you will need to pull the trans out of the car to see what condition you have.
  3. #3 Re: tranny leaking.....
    Feb 2008
    Canton, NC
    thanks tranny man
  4. #4 Re: tranny leaking.....
    Feb 2008
    Canton, NC
    Well, its my torque converter. The bushing in it was wore out, causing the seal to leak. I was told everything else looks good though.
  1. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  2. 98 Grand Prix GT 3800 V6 leaking oil
    By Fritcr in forum General Tech Discussion
    Last Post: 04-09-2008, 10:59 AM
  3. Leaking Antifreeze
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 08:13 PM
  4. Fluid Leaking out of Axle Seal Still
    By Metallistar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 04:39 PM
  5. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
