Thread: Another year compatibility "what would it take" thread...
Results 1 to 1 of 1
  1. #1 Another year compatibility "what would it take" thread...
    Feb 2008
    San Diego, CA
    Call this an offshoot of this thread, and taking it "in reverse":
    http://www.grandprixforums.net/f21/s...yman-2706.html
    Suppose I wanted to drop a 2003/2004 transmission into a 1998 H-body. From looking at the thread above and other sources (especially the tripleedge website), it seems I would need to swap in (from a 98-ish trans):
    -Valve body with 2-piece pump, multiple fluid pressure switch, separator plate
    -EPC solenoid
    -Harness
    And install an external shift selector switch.
    What about channel plate differences? I'm unclear on that, even after reading the tripleedge website.
    And what exactly would I need to do to adapt the cooler line fittings on a 2003/2004 trans to work with the 1998?
    Anything else I'm overlooking here?
    (Again, note that I'm not worried about gear ratios and TC/stall...I've got the DHP powertuner for that)
    Thanks for any info.
    EDIT: Maybe I need to be more clear what I'm trying to do. I have a 1998 H-Body (LeSabre) and a 2004 H-Body (LeSabre). I am looking to do an engine and trans build that will go into the 1998 now, and can be transferred over as a unit (with maybe a few swapped trans parts) to the 2004 in a few years. I think I'm OK with the engine part...it's the trans part I need massive help with. I already have a complete 1998 4T65E-HD (out of a Regal GS) that can be used for donor parts; I'm thinking that for this "master plan" of mine, Id also want to pick up a 2003/2004 4T65E and do the trans build using that one as a base.
  1. What is K-factor "R115" on 4T65E TC?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2008, 01:07 PM
  2. Some 4T65E year compatibility questions; Trannyman?
    Last Post: 03-31-2008, 05:14 PM
  3. "Mark All As Read" option?
    By VinnieGTP in forum Forum Bugs/Suggestions
    Last Post: 01-06-2008, 12:03 AM
  4. There should be a "Forum Bugs/Suggestions" section
    By syP in forum Forum Bugs/Suggestions
    Last Post: 12-13-2007, 07:48 PM
