Thread: Just got grant rebuilt, front end wobble
Results 1 to 8 of 8
  1. #1 Just got grant rebuilt, front end wobble
    Wichita
    Ok so I just got my car back from the shop with a rebuilt tranny about 2 days ago. Omw to work today the whole front end started to shake like it had a loose wheel. It's not a loos wheel. Any ideas?
  2. #2 Re: Just got grant rebuilt, front end wobble
    Kansas
    They put your tires on wrong.. Do you have directional tires on your wheels? Same thing just happened to me after getting pads replaced.
    If they took your tires off that might be the case.
    SOLD 1999 GT Silvermist TS
  3. #3 Re: Just got grant rebuilt, front end wobble
    Jul 2008
    sumter,south carolina
    did they put the sub frame back on
    02 GTP with mods 05 GP for DD
  4. #4 Re: Just got grant rebuilt, front end wobble
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    GOD these cars are notorious for front end wobble!!! Well since they took your axles out I would check the axles than move to suspension. Jack it up check the ball joints, tie rod ends, etc. ACTUALLY scratch that THEY need to fix it since it happened after they worked on it call them and see if that's a possibility
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  5. #5 Re: Just got grant rebuilt, front end wobble
    Apr 2009
    stockton ca
    YUp plain and simple take it back and have them fix the wobble they should have aligned it as well if they didnt they need to
  6. #6 Re: Just got grant rebuilt, front end wobble
    Wichita
    It's a Bad wobble, **** yes I'm takin it back monday. They screwed it up they fix it. Thx for the suggestions.
  7. #7 Re: Just got grant rebuilt, front end wobble
    Wichita
    Something goes ca-clunk ca-clunk too, like a wobbling loose rim. Whatever, Chance Transmissions will be fixing it or I want my munnies back.
  8. #8 Re: Just got grant rebuilt, front end wobble
    Wichita
    Found out what's wrong with the car. I noticed my rear LH wheel has a very nasty toe in. Took a look under the car & I found a broken trailing arm. Who would've guessed?
  1. Wobble/shake at around 3400 rpm
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2011, 08:47 AM
  2. Front End Phantom Wobble
    By 02BlueGTP in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2010, 11:04 AM
  3. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  4. Just got it Rebuilt
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-21-2008, 07:31 AM
