Thread: Exploded my cv axle
Results 1 to 12 of 12
  1. #1 Exploded my cv axle
    Banned - Busted For Scamming
    Feb 2009
    Well i grenaded the pass. side cv axle yesterday, any thoughts? Axle was only about 15k old, just out of the blue, took off from a light, burnt some rubber... crunch and BANG lol
    Inner tripod was the failure point. Im not running that much power, any others had this problem?
  2. #2 Re: Exploded my cv axle
    Apr 2009
    stockton ca
    ive seen it happen on poorly rebuilt ones or if there was a hard turn envolved with hard accel
    lowered cars tear them up a bit faster aswell
    could have just got a bum axle
  3. #3 Re: Exploded my cv axle
    Portland Oregon
    If it wasn't a failure of the actual CV axle, you have a weak motor mount. I torqued my motor mount so hard with a launch on some DR's it popped the boot off and separated the tripod from the cup. I since then bought the poly motor mount from ZZP and it's locked up tight now with a new lifetime warranty napa axle.
  4. #4 Re: Exploded my cv axle
    Feb 2009
    No it was just the axle, no motor mount movement. You can reach down and the inner tripod just clanks around so something just snapped in there, not taking it apart to see because i have it under lifetime warranty.
  5. #5 Re: Exploded my cv axle
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    ive seen this happen before a couple times. it happens because of poor castings,or bearings where not properly greased before they where sealed causing them to lock up and snap the tripod
  6. #6 Re: Exploded my cv axle
    Feb 2009
    Yea i just looked at it, it freewheels easy as hell lol. The inner tripod stays stationary while the shaft going to the hub just spins. Piece of ****.
  7. #7 Re: Exploded my cv axle
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    this happened to me on a 1400mile CV i went out and ordered a ZZP CV and never happened again it was the passenger side as well.
  8. #8 Re: Exploded my cv axle
    hutto, tx
    i definetely hold the record i got 4 blocks from the shop after having it replaced when it shifted it was all like boom wwwwwwwwwwhhhhhhhhhhhhaaaaaaammmmmmmmmmmmmmm lol
  9. #9 Re: Exploded my cv axle
    SE Level Member mycutlassblue's Avatar
    Louisville, KY
    I have bad struts and was accelerating on a hard turn that had a bump in it.. After I slowed down it was clunking so bad I though the engine went out, but it was the cv boot flapping around and being torn up.
  10. #10 Re: Exploded my cv axle
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    i also have this problem...i replace the passenger side cv shaft four times a year..was so confused by it that i even swallowed my pride and had a pontiac dealership look at the car and they were just as confused as i am
  11. #11 Re: Exploded my cv axle
    Feb 2009
    China axles FTW!!
  12. #12 Re: Exploded my cv axle
    Louisville, KY
    If they made everything heavy duty I would invest the extra money.. I hate cheap parts.
  1. Oil Filter Exploded Off Car
    By hostilehouse in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-26-2010, 08:44 PM
  2. Axle replacement.
    By DnaProdigy in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2009, 09:28 PM
  3. CV Axle questions
    By I4NI in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 01:45 PM
  4. My Differential Exploded! Carnage Inside
    By Abrasive in forum The Rant Forum
    Last Post: 09-16-2008, 12:41 AM
  5. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
