I recently purchased an '08 GXP as my daily driver. While cruising to work at about 50-55mph I've noticed the RPMs drop and hold steady at 1500. Can this be right? Is the overdrive that tall?
Keith
Keith
Yup. My GTP does the same thing. At 55 its around the same thing. No worries its just over drive kicking in.
my 98 gtp does that, the torque converter is locking up and preventing slippage, next time you are cruising along at 1500 rpm touch your brake and this releases the lock, its for better mileage and is a good thing.
yep, your right, works either way. sure helps the mileage on trips running a low rpm.
