Thread: Can I rebuild my Trans????
Results 1 to 20 of 23
  1. #1 Can I rebuild my Trans????
    Donating Users timboku's Avatar
    Montgomery, IL
    Can an average person with mechanical background rebuild a trans? I am pretty mechanical and have pulled motors and done all my own work. I need to pull my current motor and I figured I could replace/rebuild the trans if I can not find a good used one.
    Anyway, I saw a dvd on Ebay for 30 bucks or so. If I buy a rebuild kit from triple edge, can I do it myself and is there any special tools you need?
    Just wondering if anyone has any expierance with this and about how long it took? Thans.
  2. #2 Re: Can I rebuild my Trans????
    Wichita
    I wouldn't go near a transmission without professional help.
  3. #3 Re: Can I rebuild my Trans????
    Nov 2009
    Grand haven
    ^^^^ X2.
  4. #4 Re: Can I rebuild my Trans????
    Wichita
    So I'll probably be taking mine to a tranny repair shop
  5. #5 Re: Can I rebuild my Trans????
    Montgomery, IL
    Whats a good price for a rebuild at a tranny shop?????
  6. #6 Re: Can I rebuild my Trans????
    Banned - Busted For Scamming
    Feb 2009
    You dont have to be a pro but it helps. Get an astg manual and read it. There are a couple special tools but a little improv goes a long way.
  7. #7 Re: Can I rebuild my Trans????
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I've done it, and it's really not that bad. As minichopper said, get the manuals, read them thoroughly. There's a ton of info posted here as well from when Trannyman was more active, it's worth going back through all of the old posts. Research is key.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: Can I rebuild my Trans????
    Apr 2009
    stockton ca
    its doable and theres certain things you can have a local shop do like the teflon seals and a couple other things if im not mistaken
  9. #9 Re: Can I rebuild my Trans????
    i always thought it was cheaper (read 'saved time') to just swap in another used stock unit and be done with it.
  10. #10 Re: Can I rebuild my Trans????
    Montgomery, IL
    Can not find a lower mileage one around here. Found one with 90K on it for 600. Figured a rebuild would be cheaper and I could learn. The GXP is coming out for the summer so I have time to work on it.
  11. #11 Re: Can I rebuild my Trans????
    May 2008
    McHenry IL
    i did mine myself with nothing more then a manual i got on ebay and some goods from triple edge performance and a buddys hand when i needed to align parts.
    have confidence my trans is great.
  12. #12 Re: Can I rebuild my Trans????
    May 2008
    McHenry IL
    all together i had some damage etc so i was at about 870 or so.
  13. #13 Re: Can I rebuild my Trans????
    Montgomery, IL
    Quote Originally Posted by GTPJOE90 View Post
    Did you put any performance stuff in.....Harden shafts or anything?
  14. #14 Re: Can I rebuild my Trans????
    May 2008
    McHenry IL
    yeah dave at TEP can help you with info if needed or just read and do it like me
  15. #15 Re: Can I rebuild my Trans????
    canada
    I love working on my own stuff but when it comes to tranny's u need to know what ur doing, I would seek pro help
  16. #16 Re: Can I rebuild my Trans????
    Feb 2009
    Holy crap joe you got ripped the **** off. Hardened 4th shaft, master rebuild kit, new bushings, new bearings plus rebuilt converter only cost me $400.
  17. #17 Re: Can I rebuild my Trans????
    CT
    Yeah but other things like a new torque converter can throw that up to 800 rather quickly.
  18. #18 Re: Can I rebuild my Trans????
    Feb 2009
    Why spend more then you have to? Rebuilt converters are just as good as any other.
  19. #19 Re: Can I rebuild my Trans????
    QCA, IA
    throw in chains, valve body fixes/upgrades, fluid, etc and it all adds up. Mine came in around $750 with a rebuilt converter, but that includes buying the transmission.
  20. #20 Re: Can I rebuild my Trans????
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    the only trans ive been in is an allison 1000. those are cake. if been in a ten steed out of a semi. those arent too bad. never done a FWD car before tho.
  1. 4t65e hd TRANS REBUILD ! " with pics "
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2010, 09:38 PM
  2. Engine and Trans rebuild??
    By EarlyGTDriver in forum General Tech Discussion
    Last Post: 03-08-2010, 11:35 PM
  3. 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    By GrandPrixGT300 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2009, 12:42 PM
  4. Motor & Trans Rebuild Questions
    By BlackGhost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2008, 10:16 AM
  5. Looking for Trans Rebuild Info
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 12:03 AM
