Thread: cant get my trans out
Results 1 to 11 of 11
  1. #1 cant get my trans out
    united states
    i have been working on my 2001 bonneville and taking the trans out i have taken out all the mount bolts and bell housing bolts and torque converter bolts i can find and it is still not coming out am i missing something
  2. #2 Re: cant get my trans out
    Outer Space
    Unbolted tranny and engine mount?
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: cant get my trans out
    Portland Oregon
    Did you get the tailshaft to block bracket on the passenger side and the reverse belhoising bolt?
  4. #4 Re: cant get my trans out
    united states
    there is a reverse belhousing bolt where would that be located at
  5. #5 Re: cant get my trans out
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    look straight down the passenger side between motor and trans u gota take the tail shaft bracket off to get to it .its hard hard too see you need like a 5foot extention and a swivel 18mm it ill come right out
  6. #6 Re: cant get my trans out
    Apr 2009
    stockton ca
    Yes the famous B!TCH bolt its not that bad to get to like others have said and a long extension
  7. #7 Re: cant get my trans out
    united states
    what do i have to do to get to it easier
  8. #8 Re: cant get my trans out
    Charles City, IA
    Take the heads off.
    SMGPFC Two Nipple General
  9. #9 Re: cant get my trans out
    Apr 2009
    stockton ca
    Quote Originally Posted by gpgtman83 View Post
    Its easy to get to you just need a long extension maybe a auto stor can rent you one ?
  10. #10 Re: cant get my trans out
    GTX Level Member killakross5o4's Avatar
    illinois
    u get the money?
    Shortstack Intercooler, 1.9 Rockers, 3.2 pulley,180 drilled T stat,103 plugs, U bend delete with no cat, thrush resinator,3inch pace setter cat back,shift kit,ZZP Chrome tips,,ZZP stage 2 throttle body,homemade 4 inch CAI,DHP tuned PCM,SSAC headers
  11. #11 Re: cant get my trans out
    Feb 2010
    ohio
    just take the bracket on the end of the trans off and put a 18mm and a bunch of extensions on the ratchet and spin it out
  1. trans going out?
    By chuy09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2010, 10:03 PM
  2. what my trans is doing
    By Jesse1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-09-2010, 11:29 AM
  3. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  4. trans from l36,using a l67
    By srziemkowski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2008, 06:16 PM
