Thread: trans problem hellllppp
Results 1 to 9 of 9
  1. #1 trans problem hellllppp
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    i got a 03 grand prix gt 90k wen im hold a constiant speed the rpms want 2 jump back and fourth any ideas ?? just did a filter and fluid, shifts excellent (firm) barley any metal other than normal in the pan let me kno if any suggestions thanks
  2. #2 Re: trans problem hellllppp
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    sounds like tcc to me, is this happening at or above a certain speed? no codes from the engine light? may not even be trans related. could be icm...
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: trans problem hellllppp
    Feb 2010
    ohio
    no codes, its just wen i hold a steady speed could be goin 25mph and rpms go up and down 500 rpms, whats the icm whats that do??
  4. #4 Re: trans problem hellllppp
    Missouri
    Same here if you ever figure this out please let me know lol
  5. #5 Re: trans problem hellllppp
    Feb 2010
    ohio
    (40mphgt) whats your car doin??
  6. #6 Re: trans problem hellllppp
    Missouri
    Well not all the time but if I take off slow as first then slowly lay into it it well jerk into gear and the higher I get into first gear, it will be jerky like I guess too best explain it. Buy 2nd 3rd 4th are all good. Its kinda wierd but it seems as if the valve body is sticking
  7. #7 Re: trans problem hellllppp
    hutto, tx
    trannsmission shop showed my tranny pressure fluctuating rapidly which when fixed in turn fixed my jerking ill see if i have a video of jerking to post and relate with you
  8. #8 Re: trans problem hellllppp
    Missouri
    That would be awesome. How much work was involved to fix that and how much?
  9. #9 Re: trans problem hellllppp
    Feb 2010
    ohio
    mine dont jerk tho you cant even tell it does it you juss gota watch the rpms when ur cruisen
  1. Strange Trans. problem...help!
    By lastonemade02 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2009, 08:07 AM
  2. Trans problem
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2009, 01:00 PM
  3. Weird Trans problem
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2009, 01:27 PM
  4. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
  5. 98 GT Trans Problem
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2008, 09:47 PM
