Lmao...a NICE school called mcc, has to be the funniest thing I've heard all week
I was thinkin about rebauilding my trans, but eh, this one's good for now, I'll drive it till something breaks.
Never.
trans is up in here attached to the enginewensday 3.10.10 she will be roasting rubber everywhere
class was cut short "jsut my luck" so we couldnt bolt cradle and hook stuff up yet in time though in time
we also magic dragon'ed the trans case she looks pearly new ha
You know you will have to probally align it too right?
i was lucky with mine the alignment wasnt off by a noticable amout
if so theres a alignment machine at school next door LOL
tomarrow marks a awesome feeling and cheerful day or a big steaming dump on my chest...... i hope its option A. ill update tomarrow night![]()
to make a long story really short for today.....
I F$($ING LOVE MY CAR!!!! LOL went great shifts amazing with shift kit and 4th gear is back hehehehe AMAZING DAY FOR ME ha. but i do have a electrical issue... 1 my information center resets itself and turns tcs on and off randomly and zeros out the mpg and oil life info and then when i shut the car off it wont start and seems like bat is dead... the bat was just replaced b4 i did trans..... but jumped started it fires right up... im thinking wiring or ground issue..also my trans shift interlock is messed up and to shift i have to jam a pen down the hole idk how to fix that....
this happened before i took trans out so yeah install was sucess just have 2 bugs to work out. any suggestions or heelp??? thanks i appreciate it. also the alignment is perfecto!
yeah im thinking a loose trans connecter me and urlosn said check starter grounds n stuff and trans connectors well see tomarrow and for the trans shift interlock imma permanetly disable her hehehe its pointless anyways
im at 12.02 volts at bat.... im thinking bad bat..... who knows by why would the drivers info center flip a **** imma check underneath and the starter tomarrow.shes almost there i just fixed the shift interlock good ol handy dandy 2 zipties to hold the gay plastic clip down a bit no more problems
now bat issue.
I had the same problem Joe, last month (after the tranny R&R). No prior starting or battery problems prior to the tranny rebuild. All of a sudden, slow start or no start. I took the car to AutoZone for an alternator check, showed 104 AMPS on the testing station. I had checked the battery connections the day before and cleaned them up (really well, I thought). AutoZone found a loose terminal while there, tightened it up (on the battery itself). Later that same night, same problem. No start. Always jump starts though, NP. Next day, NP starting. My mechanic (Evan) that did the R&R said to bring it by, the next day. He took care of a leaking oil level sensor. He said he did not have to do anything to the charging system or the starter. He said he started it 30 times, NP. I went to pick it up, NP since. No trouble now going on about 3 weeks, including some nighttime driving (about 450 miles all total). Really weird problem drove me nuts for about a week. Good luck.
Congrats on the tranny re-install!
thanks man!
jacked her up at school 3 three grounds for the alternator were in 2 different locations so i put them all together and that cured all problems..... wierd but ill take it hahaha
shes a champ now!!! thanks again guys for advise and info and DAVE at triple edge performance is the man FYI
congrats joe!
nice!
FYI 12 V =40-50% charge
