Thread: urgent is my tranny hooped
Results 1 to 5 of 5
  1. #1 urgent is my tranny hooped
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    hi i my transmission isn't shifting right or is slow to enguage latley my 1-2 shift will clunk when is shifts more when its cold and the car feels like is down on power cuz of power loss from the transmission not shifting right or sliping very mild slip though any thoughts
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: urgent is my tranny hooped
    SE Level Member joshuayobal's Avatar
    Brunswick, GA
    I had a similar problem to yours... My transmission would clunk on 1 and 2 and felt like it strained to get to third...When I had shut the car off and turn it back on...it shifted correctly. Well, I fix that problem...It happen to be the Pressure Control Solenoid in the transmission. This part deals with the clutching of the transmission. I put that in and it fixed it...I had put it on a computer and it coded that it needed the PCS. So, I had a friend mechanic fix it for me. Also...he recommended changing the transmission fluid after you put the new piece in. I used Castro Dexron 6 (VI) If you can get a hold of the Mobile 1 6 that would be good too...Read your manual to make sure that it takes that kind of transmission fluid first though lol. I hope this helped...
  3. #3 Re: urgent is my tranny hooped
    I say try dropping the pan first and putting in a new filter...then replace the fluid with Dexron VI...if that doesn't help...have fun...most anything transmission related is either cheap and a PITA, or expensive and easy...or expensive and b!tch...take your pick
  4. #4 Re: urgent is my tranny hooped
    i changed the tranny fluid like 7000 km ago
    sold 97 GTP stock
  5. #5 Re: urgent is my tranny hooped
    michigan
    lol i agree... 7 dollar seal for my trans and i gotta pull the whole damn thing apart just to get to the damn thing lol.
  1. Help urgent!!! No start (Park Avenue)
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 11-01-2008, 07:39 PM
  2. URGENT! Hard Shifting and Transmission Whine!!!
    By lvin4jc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-21-2008, 08:46 PM
  3. urgent dead car
    By Sunstone in forum General Tech Discussion
    Last Post: 09-07-2008, 12:22 PM
  4. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
  5. Urgent: Pfyc F1 Hood Owners!
    By shaferz in forum Off Topic Discussion
    Last Post: 08-07-2008, 06:13 AM
