Thread: Tranny fluid and filter change
Results 1 to 13 of 13
  1. #1 Tranny fluid and filter change
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Can anyone point me to a link about a tranny filter change. I got a 2006 N/A. Im just looking for tips and the correct bolt sequence to tighten the pan back up when all done. Pretty much Im lookin for a write up if there is one or just a good link. I searched nothing to uselfull tho. thanx fellers
  2. #2 Re: Tranny fluid and filter change
    PA
    I don't know of a writeup off hand. Maybe search for instructions on how to do a DIY shift kit and try to follow them.
    But basically, you just want to loosen all the transmission pan bolts and then take them out one by one. I usually start at one end and work my way back loosening them and taking them out as I go so the pan will fall on one side a little and get most of the tranny fluid in the pan. But it can be quite the mess. So have lots of rags ready and newspaper down.
    With the pan off, you can pull the filter straight down. It may take a little wiggling and twisting, but it will come out. Then clean the pan and gasket. If it is a stock gasket, you should be able to just wipe it off and reuse it. Put the new filter up in. Put the pan on and tighten the bolts. Not sure what the spec if to tighten them to. But just snug basically. Don't over tighten them. Then fill with 7 quarts of fluid or so. Start the car, check for leaks. Test drive. And check fluid level. Add if necessary. Make sure to check the fluid every couple days for awhile to ensure it is correct.
    Repeat every 30k miles.
    2001 GSE
  3. #3 Re: Tranny fluid and filter change
    according to haynes 156 in-lbs
  4. #4 Re: Tranny fluid and filter change
    Oct 2008
    IL
    Anyone got any idea what I should torqe the bolts to??? Unless 156 is it but that sounds carzy tight
  5. #5 Re: Tranny fluid and filter change
    Thats inch pounds.... which translates into exactly 13 foot lbs.
    Inch pounds is more accurate when dealing with such low values.
    The other commonly accepted value is 8-9 Ft Lbs which is 96-108 in-lbs.
  6. #6 Re: Tranny fluid and filter change
    MO
    The other commonly accepted vale is 8-9 Ft Lbs which is 96-108 in-lbs.
    Math is Power!!!
    <brandonl2000> LMAO D!!
  7. #7 Re: Tranny fluid and filter change
    Oct 2008
    IL
    Nevermind just read on triple edge its 10
  8. #8 Re: Tranny fluid and filter change
    Note, the lower torque rating is for the 3t40, not the 4t65e which you have.
  9. #9 Re: Tranny fluid and filter change
    Oct 2008
    IL
    Thanks alot for clearin that up. I was getting a lil lost in all that. Math is so power too but me being good at math went out the window sometime in high school sadly. Anyway Huge help fellas
  10. #10 Re: Tranny fluid and filter change
    Charles City, IA
    Snug with a 1/4" ratchet is good.
    SMGPFC Two Nipple General
  11. #11 Re: Tranny fluid and filter change
    Donating Users Ibwrong's Avatar
    Oklahoma City
    ^^Thats what I have always done..
    AlldataDIY shows 10ft/lbs
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  12. #12 Re: Tranny fluid and filter change
    If you're working on cars, you should at LEAST know that 1 ft lb = 12 in lbs. Its just the difference between inches and feet.
  13. #13 Re: Tranny fluid and filter change
    Oct 2008
    IL
    well when you put it that way I can understand it. I get by on maintnance stuff pretty good. Just never anythng to in depth I pay my buddy for that. Hopfully this thread will help somone else along the way that couldnt find wht i was looking for
  1. changing fluid and filter in tranny???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-23-2012, 06:06 AM
  2. Supercharger fluid change 01 gtp
    By brownb66 in forum General Tech Discussion
    Last Post: 11-19-2009, 07:41 AM
  3. advice on tranny pan drop/filter change-trannyman?
    By Liquifire in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2009, 11:45 PM
  4. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
  5. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
