Thread: Transmission swap question
Results 1 to 6 of 6
  1. #1 Transmission swap question
    oklahoma
    I have a 98 GTP with a bad transmission and I was wondering if one out of a 99 regal gs will work. Thanks for any help!!!
  2. #2 Re: Transmission swap question
    Charles City, IA
    You would need a tune they have a different gear ratio.
    SMGPFC Two Nipple General
  3. #3 Re: Transmission swap question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    *sigh* They have the same gear ratio.
    The only thing to watch out for would be the cooler line fittings, your 98 is going to have threaded fittings, where the 99 could be either threaded for quick connects.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: Transmission swap question
    oklahoma
    Quote Originally Posted by Scimmia View Post
    Cool Thanks!!!!!!!
  5. #5 Re: Transmission swap question
    Charles City, IA
    I thought for sure they have different gear ratios.
  6. #6 Re: Transmission swap question
    oklahoma
    Can I change the gears very easy? Do they come out of the pass. side or do you have to take the hole trans apart?
  1. Help needed with transmission question...
    By steelcash in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-26-2009, 05:43 PM
  2. Transmission question
    By dearmond in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-26-2009, 03:11 PM
  3. transmission swap questions
    By codyc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2009, 09:25 PM
  4. Transmission swap
    By ddyke2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2009, 10:19 PM
  5. question about my transmission
    By 01prixse in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-27-2009, 05:00 AM
