Hey, havent ever posted on here, but im trying to pull the driver side axle on a 99 GP 3.8L and when i did finally get the circlip to break loose it also pulled what I assume is the output shaft. I need to know if I can just pull that on out and throw it in a vice to remove it, or will pulling it out cause me problems? thank you
