Thread: '98 WON'T go into OVERDRIVE
Results 1 to 5 of 5
  1. #1 '98 WON'T go into OVERDRIVE
    minnesota
    I have a '98 grand prix GT that wont shift into overdrive. it's running about 3100 rpm at 70mph and when I shift the shifter from OD to 3rd, the tach doesn't move. Otherwise the tranny works just fine...no hard shifting, slipping or anyting. Any chance the is something fairly cheap or simple? Any help would be appreciated. Thanks!!
  2. #2 Re: '98 WON'T go into OVERDRIVE
    Banned - Busted For Scamming
    Feb 2009
    4th clutch hub
  3. #3 Re: '98 WON'T go into OVERDRIVE
    minnesota
    After doing a little more research on this site, I see that the 4th gear clutch hub is a pretty common problem. How big of a job is this? something a guy could get done in an afternoon or is it fairly big job? What would I have into parts if I did it myself? Thanks again!!
  4. #4 Re: '98 WON'T go into OVERDRIVE
    Jersey
    welcome to the 3spd club! its rebuild time
    fwiw I lost 4th gear sometime around early september late august and ive been driving the car hard, metal shavings are all in the trans, rad, and my nice new desert fox trans cooler, i drive it hard everyday and still hasn't taken a total **** yet.
    16' wrx sti- stock
  5. #5 Re: '98 WON'T go into OVERDRIVE
    To get at the hub. It's drop trans enough to get the side cover off. Then remove a much of parts to get at it. Luckily..it's pretty close to the side cover.
  1. Transmission will not shift into overdrive
    By JennysGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2012, 10:37 PM
  2. trans overdrive problem?
    By Viperhunter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 01:22 PM
  3. No overdrive
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2009, 02:31 AM
  4. Transmission Overdrive Problem
    By Egleone6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2009, 08:49 AM
  5. Overdrive Problem (does not seem to be one)
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 10:02 AM
