Thread: '97 Riviera trans in my '97 GTP?
Results 1 to 8 of 8
  1. #1 '97 Riviera trans in my '97 GTP?
    Feb 2008
    Will the transmission from a '97 Buick Riviera work in my '97 GTP? I know the driver's side mount is different, but are there provisions for the GTP mount to be transferred over to this transmission?
  2. #2 Re: '97 Riviera trans in my '97 GTP?
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i would be worried about the gear ratio in the trans, i believe the two are different, u may have to repeogram your pcm for it to work properly....hope you get more help.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: '97 Riviera trans in my '97 GTP?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    As long as the trans was from a supercharged car it will work ok. The Riv uses different mounts that arent used on the Wbody cars but is not a problem to work around. Just swap the mount with the ones from your GTP and it will install ok.
  4. #4 Re: '97 Riviera trans in my '97 GTP?
    Feb 2008
    That's good news! I'll go out there next week sometime and see what kind of deal i can get on it. $200 or less, hopefully.
    What about the axles? Are they the same length on both sides?
  5. #5 Re: '97 Riviera trans in my '97 GTP?
    Use your axles. Riv axles should be longer than GP axles.
  6. #6 Re: '97 Riviera trans in my '97 GTP?
    Feb 2008
    I was just hoping I could grab one or both for spares. Oh well. No big deal. Now, I just need to get out there with a truck and some cash!
  7. #7 Re: '97 Riviera trans in my '97 GTP?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    From my own experience it's better to get one from a salvage yard rather than picking one from a pick-n-pull yard. Atleast you know it was out of a running car and usually they come with some sort of waranty. Payed well over $900 trying to get a trans I pulled to work. No luck as with one problem fixed another popped up. Ended up paying $400 for a trans out of a running car from a salvage yard some time after. Save yourself the headache and cash!
    Also, try and find a newer trans. Especially with the supercharged models, you know they've been driven hard and it's not worth the risk of burnt clutches, bad solenoids, etc.. Lastly, it doesn't have to be the same age. For intance, I picked up a GT trans out of an 02 (which I believe is the last year before they started changing valvebodies) and I have a 98.
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  8. #8 Re: '97 Riviera trans in my '97 GTP?
    Feb 2008
    The car I'm pulling it from was driven to the yard by an elderly couple that just didn't want it anymore because the s/c was rattling and they thought the engine was shot. Before I got the blower off it, the yard owner let us throw a battery in it and fire it up. Smooth and quiet except for the s/c.
  1. '80 riviera 3.8 L conversion
    By NiceGuy in forum Turbo
    Last Post: 09-01-2009, 10:26 PM
  2. 1996 riviera with a series 2??
    By chevyy1212 in forum General Tech Discussion
    Last Post: 07-18-2009, 08:00 PM
  3. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  4. trans from l36,using a l67
    By srziemkowski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2008, 06:16 PM
  5. BMW 325ci vs My Buick Riviera ... burnout contest
    By oldsman105 in forum Track Sessions and Kills
    Last Post: 02-02-2008, 05:40 AM
