Thread: trans overdrive problem?
Results 1 to 7 of 7
  1. #1 trans overdrive problem?
    wisconsin
    I just bought this 98 gtp and im trying to figure out the way to turn on and off the overdrive. I know theres a button on the shifter and it should show a light on the dash when its on or off but when i push the button in or out it does nothing and shows nothin on the dash any ideas??!
  2. #2 Re: trans overdrive problem?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Put the shifter in "3" and you'll get no overdrive. As simple as it gets.
    The button on the shifter is for Performance Shift, it shifts a little quicker and at slight higher RPM.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: trans overdrive problem?
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Welcome to the site.
    My EX wifes other car is a broom.
  4. #4 Re: trans overdrive problem?
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    some folks have drove a while with this condition. i hear there is something that strips out inside the trans that has to do with fourth gear. thats what our overdrives are is 4th gear and a tcc lock up. unfortunatly there are some folks who get this condition and know that the trans is on its way out. i had my first hand experience it took me o a month to kill the trans lol i got the car with no 4th gear so who knows how long it drove b4 i did the damage. do some research on this site and there is some info on replacing this bad piece and making the trans work right. its not easy. i hear it can be done in the car. just start to prepare yourself and maybe look for a used trans or even a rebuilt one. as most people know the "triple edge performance" advantage stands out on this site and on the reliability and durability. keep us updated.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  5. #5 Re: trans overdrive problem?
    wisconsin
    i was wrong on my question it goes in overdrive fine its the prefer switch that doesent work on the side of the shifter....
  6. #6 Re: trans overdrive problem?
    Barksdale AFB, LA
    Quote Originally Posted by Viperhunter View Post
    That switch is not for overdrive. That controls performance shift. If you don't want overdrive you put it in "3", not "D". That's how you tell it what you "prefer".
    2009 Subaru Impreza WRX STI
  7. #7 Re: trans overdrive problem?
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    my performance shift wasnt working either till i took my center counsel apart and found the wires were broke off.. maybe from getting pinched in something from the shifter? i soldered them back together and works fine now
  1. Trans problem
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2009, 01:00 PM
  2. Transmission Overdrive Problem
    By Egleone6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2009, 08:49 AM
  3. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
  4. 98 GT Trans Problem
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2008, 09:47 PM
  5. Overdrive Problem (does not seem to be one)
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 10:02 AM
