Re: Have a 4T65E Question? Please Read! Triple Edge contact info
Got a 2006 grand prix base 137800mi and I'm noticing when the trans gets to about 174* but gets worse around 200-205* it starts this shuttering on occasion when I start from a stop it will hesitate a second then shutter and slam into first then shifts fine through the rest of the gears. Also noticed that after stopping a few seconds later it will shutter occasionally and rpms go and down I thinks its changing gears but I'm stopped? Would a trans fluid change help any or is it just the worst case scenario that the trans will need to be rebuilt?
What condition is the fluid in? Last time is was changed? I would start with dropping the pan, putting new fluid in and a new filter. See if that fixes the issue.
2006 Base, When adding oil to tranny do you put it into the hole where you pull the dipstick?
i sent triple edge an email, i look forward to your reply
-joe hutzman
Will adding a shift kit shorten the life of my 126K mile trans? It has that front pump whine and has for about 30K miles since I bought it, other than that it seems fine.
Thanks
A shift kit should not shorten the life. By engaging the clutches faster it typically is considered to extend the life of the clutches with minimal added force/pressures on the hard parts. However if you have other existing issues, it may not help or mask them.
BillBoost37
Thanks, that's what I figured, I don't expect it to fix my whine but that would be nice!
MBruneaux
It probably won't go anywhere. I installed my shift kit 3 years ago, and the wine is the same as before the shift kit. The good thing is that it hasn't gotten any worse.
I have a question about 4t65E-hd..... I have seen a chain conversion kit , so I am asking if there is a belt in the trans-axle?
No damn belt the CVT transmissions can keep them worthless things.....
The chain upgrades are thicker chains than stock.
V8 spec chains from the LS4 cars TEP stocks.
7/8s chain upgrade. TEP stocks.
1inch chain few around in the classifieds but your going to pay close to 2k for one with gears.
15/16ths chain set used to be an aftermarket option but the 7/8s sets are way more common and stronger.
My wife has an 2003 GT 3.8l - Her transmission is starting to develop issues. Im considering swapping the engine and transmission for a lower milage combo. What years adn models can i use for a donor ? Can I swap in a GTP set up . thanks
My wife has an 2003 GT 3.8l - Her transmission is starting to develop issues. Im considering swapping the engine and transmission for a lower milage combo. What years and models can i use for a donor ? Can I swap in a GTP set up . thanks
Can you, yes but there are differences beween the years.
97-02 tranmission are different than 2003+. On the outside they are the same but inside they are slightly different and controlled different.
For a direct plug and play trans swap without doing anything else, you'd need to find another 2003 transmission or get yours rebuilt.
Hey yall Im having an issue with my 2003 grand prix. When i am coming up to a stop sign or parking ect when my speed drops to 10 miles per hour everytime pretty much on the money the transmission seems to slam down into gear. Any helps appreciated
Time to pull the codes. Bet you are seeing a TCC or max adapt shift.
