Thread: Tranny Filter Gasket
Results 1 to 5 of 5
  1. #1 Tranny Filter Gasket
    Wichita
    I took out the transmission filter & the gasket stayed in the tranny. I tried w/o luck using a screw driver to pry it out. =\
  2. #2 Re: Tranny Filter Gasket
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Easiest just to leave it in there, but if you tried a screwdriver already, it's probably damaged, so too late. A seal puller works great, otherwise just keep prying on it and/or grabbing it with a vise grips. Be careful not to damage the case, though.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Tranny Filter Gasket
    Banned - Busted For Scamming
    Feb 2009
    You have to use a screwdriver and a hammer to beat one side in, collapsing the seal without damaging the case. It can be done and is done every time i change my tranny filter.
  4. #4 Re: Tranny Filter Gasket
    If that fails... Chisel.
  5. #5 Re: Tranny Filter Gasket
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Yup. What he said.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  1. changing fluid and filter in tranny???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-23-2012, 06:06 AM
  2. Lim gasket
    By cardiffGIANT98gtp in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 11:21 PM
  3. oil filter housing...need gasket or not?
    By fst in forum General Tech Discussion
    Last Post: 08-30-2009, 08:49 PM
  4. advice on tranny pan drop/filter change-trannyman?
    By Liquifire in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2009, 11:45 PM
  5. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
