Thread: Codes P0742A, P15554C and P1881C
Results 1 to 4 of 4
  1. #1 Codes P0742A, P15554C and P1881C
    South Dakota
    I was driving on the interstate today and had to slow down for traffic. When I hit resume on the cruise control the car kind of jerked, but not really, not sure how to describe it. It hesitated and then went and the cruise worked but the check engine light went on.
    I had to pass a car and thats when I noticed the transmission was shifting hard. I stopped at the next town which was a few miles away and was told at a small repair shop that I had the codes P0742A, P15554C and P1881C.
    The guy cleared the codes and said to drive it around town and if the check engine light came right back on and it shifted weird I've got trans problems. If nothing happened it might just have been a weird deal with the cruise that made the car throw codes. He explained that the rough shifting and the P1881C code was just a way for the car to protect the trans when there are other problems.
    I drove it around and everything seemed fine so I got back on the interstate and drove home which was 300 miles. I got curious about the codes so I jumped on here to see what I could find and wow the P0742A code isn't a good one!!!
    I read some of the info on the link on trannyman95's signature but I'm hoping trannyman95 or others can tell me if this was a fluke or if I have a problem and was luck to just get home!
    I've got about a 400 mile trip to take tomorrow...
    The car is a 2000 GP SE with the 3.1 and has about 125k miles. The trans was rebuilt about 40k ago. I just bought the car recently as a work car to put miles on and save some gas money. I'm now wondering if maybe this is why they sold it!
    After the codes were cleared the car drove great. I used the cruise and it worked fine too. I live in an area where there are hills and curves, along with road construction so the trans was shifting up and down. I didn't just get on the interstate and went one speed for the whole 300 miles after the issue. All seems fine now.
    Help!
  2. #2 Re: Codes P0742A, P1554C and P1881C
    South Dakota
    I just noticed I had one to many 5's in the cruise control error code.
    It should be P1554C. I'm sure you guys that know what it all means recognized that right away but thought I'd mention it.
  3. #3 Re: Codes P0742A, P15554C and P1881C
    South Dakota
    well 500 more miles after the clearing of the codes and the check engine light is back on. I'll take it to a local trans shop to find out what the problem is.
  4. #4 Re: Codes P0742A, P15554C and P1881C
    Chilliwack BC
    p0472 is the code for the torque converter clutch release switch in the valve body of your transmission. it could be numerous things and a transmission shop is definately the way to go. if that switch is failing it would produce the issues you described in your first post.
    P1554 is related to your cruise control system. and i would once again reccomend a transmission shop to have a look.
    wasnt able to find any info on the third code.
  1. codes codes codes
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 09:15 PM
  2. Have some codes need help
    By pDuB257 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 03:25 PM
  3. GM RPO Codes
    By mkuhn20 in forum General Tech Discussion
    Last Post: 01-21-2009, 04:47 PM
  4. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  5. I got some codes
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2008, 07:41 AM
