Thread: Transmission Coolers for the Middle East
Results 1 to 14 of 14
  1. #1 Transmission Coolers for the Middle East
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Hello guys!
    I'm shipping my 2000 GTP to the middle east when I leave in a month and I reckon I will need a transmission cooler since you lot use them here in Arizona, and it gets way hotter in Dubai! I wanted a transmission cooler that offers the best mixture of performance and ease of install, and need your recommendations.
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  2. #2 Re: Transmission Coolers for the Middle East
    Aim to the largest, best core you can fins and then consider adding a temp controlled fan on top of it.
  3. #3 Re: Transmission Coolers for the Middle East
    Dec 2008
    Excellent. I shall commence doing research, but can you point me to a particular product so I can start from there?
    Cheers mate!
  4. #4 Re: Transmission Coolers for the Middle East
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Look at this post and go to my post which is the last
    http://www.grandprixforums.net/f21/h...ler-17533.html
    It's definitely not the best cooler, but works very well and is probably the easiest to install and is pretty cheap too.
    You can spend $400 + on a really nice trans cooler so you need to be a bit more specific on cost.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  5. #5 Re: Transmission Coolers for the Middle East
    Dec 2008
    Quote Originally Posted by JJ91284 View Post
    Sounds perfect, thanks a lot dude!. Its in the price range I was looking at too. Cheers!
  6. #6 Re: Transmission Coolers for the Middle East
    Jersey
    get a Desert Fox one. Check out my thread on it.
    16' wrx sti- stock
  7. #7 Re: Transmission Coolers for the Middle East
    Schaumburg, IL
    Quote Originally Posted by Panzer4 View Post
    Glad I could help
  8. #8 Re: Transmission Coolers for the Middle East
    Schaumburg, IL
    Quote Originally Posted by 99prixgt View Post
    Its a nice unit, but its hard to justify something thats 3 times the prices for about 1/3 better performance.
  9. #9 Re: Transmission Coolers for the Middle East
    Jersey
    The Desert Fox unit comes with A/N fittings, barbs, hoses, custom brackets for the GP, and it is a stacked plate type rather than a tube.
    If you get the hayden you still need to purchase fittings, nylon coated hoses (unless you like the ****ty rubber ones), barbs, and A/N fittings.
    With the DF cooler, you get directions and you only need to get a quart of fluid, makes it a little easier.
    My temps don't go above 180* on a 100* day in stop and go traffic (even with a shattered 4th). When im cruising at a steady speed, I can watch the temps go down.
    1/3 performance gain? I don't know about that.
    16' wrx sti- stock
  10. #10 Re: Transmission Coolers for the Middle East
    Moore, Oklahoma
    I'm thinking about a desert fox myself in the future. Seems like a real nice unit, plus it should fit behind my FMHE...
    Shawn W. Larsen
  11. #11 Re: Transmission Coolers for the Middle East
    Dec 2008
    Hmm. Desert fox DOES look good. Heavy price but probably worth it .
    Thanks for your help guys.
    Cheers!
  12. #12 Re: Transmission Coolers for the Middle East
    Schaumburg, IL
    I agree the Desert Fox unit is nice. Their is still a flaw with that cooler, your running through the stock radiator. If I was going to spend $250 on transmission cooler, I'd run a full stand alone trans cooler. Why spend $250 when theirs been numerous people that have their radiators core leak water into the trans fluid and their goes your transmission. Or at the very least get rid of the flexible lines and run hard lines (stainless, aluminum, steel) are all better alternatives and can be done for cheap.
    It all comes down to price. That Desert fox unit is over priced for what it offers.
  13. #13 Re: Transmission Coolers for the Middle East
    Schaumburg, IL
    If you looked at the link I supplied and looked the kit PFYC sells, this is the exact kit GM recommends for a bolt in solution for $90. Its rated at roughly 20,000 GVW, while the Desert Fox kit is rated for 28,000 GVW. That would account for less than a 1/3 performance increase. Those numbers while not always accurate to the "T" gives you a rough idea of the cooling ability.
  14. #14 Re: Transmission Coolers for the Middle East
    Feb 2009
    Chicago
    good info
  1. The display in the middle on a 1998 GTP
    By shawnz90 in forum Audio, Security & Visual Electronics
    Last Post: 10-23-2010, 10:14 PM
  2. (Solved) Trannyman Help! im in the middle of trans filter change.
    By speedemongtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2009, 02:30 PM
  3. This is an East Tennessee HOWDY!!!
    By gtpcruizer in forum Introductions/Noob Questions
    Last Post: 10-07-2008, 04:52 AM
