Thread: transmision slipping
Results 1 to 3 of 3
  1. #1 transmision slipping
    puerto rico
    hi i have a pontiac gran prix 1998 and i am having problems with the transmision when its cold i put it in gear and it grabs for about 10 sec then starts slipping till it doesnt grab at all and it does a noise in the trans as if it was the steering pump without fluid what can that be?
  2. #2 Re: transmision slipping
    That would probably be a bad transmission.
    Check the fluid level and color. If you have the availability pull the codes even if the light is off. (Some codes to not illuminate the CEL)
  3. #3 Re: transmision slipping
    nova scotia,canada
    im having the exact same problem? if left to sit for a bit it will move otherwise it will start to slip again?
  1. Trans Slipping - HELP!!
    By coolken84 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2011, 01:17 PM
  2. tranny slipping?
    By 05SS45 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-02-2009, 11:36 AM
  3. transmision ??
    By french080 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2009, 07:54 AM
  4. feels like a transmision slip...
    By 52 picup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-20-2008, 01:22 PM
  5. Transmision fluid burnt. Do i flush it?
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 09:13 PM
