Thread: tcc lockup disabling???
Results 1 to 2 of 2
  1. #1 tcc lockup disabling???
    Dec 2008
    U.P.
    Anyone know where the wire is or how i can disable tcc lockup. I have a 3.1 and it has less power than my lawn mower. I was having problems with it locking and unlocking all the time which i solved but i get sick of it kicking in and out going up hills. I drive in a hilly area to work about 40 miles and i would like to keep the rpm up so it doesn't always kick down. I think it is lugging too much and would like to make the hills a little easier. If i cant it's back to the ram with the big c.
  2. #2 Re: tcc lockup disabling???
    CT
    well if the hills are steep its going to kick down, it doesn't have the torque to make it up steep hills without it. If you wanted to you can put the car in 3rd and then it won't have to shift down but keep in mind this will generate much more heat and less mileage.
  1. disable lockup 1999 regal gs
    By smokingjoe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2010, 10:35 AM
  2. 4T65E-HD lockup issue - engages really hard
    By paulaxe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2009, 09:25 PM
  3. Completely Disabling ABS?
    By SuperSport in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2009, 12:03 AM
  4. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
  5. TC lockup/unlock problems? tranny rebuild ?'s trannyman step in!
    By kyle99gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2008, 01:24 PM
