Thread: advice on tranny pan drop/filter change-trannyman?
Results 1 to 12 of 12
Threaded View
Liquifire advice on tranny pan... 07-30-2009, 10:43 AM
Toofastgs Re: advice on tranny pan... 07-30-2009, 12:13 PM
carl06GT Re: advice on tranny pan... 07-30-2009, 01:43 PM
Liquifire Re: advice on tranny pan... 07-30-2009, 03:33 PM
Liquifire Re: advice on tranny pan... 07-30-2009, 12:23 PM
Liquifire Re: advice on tranny pan... 07-30-2009, 12:44 PM
LOUDANDPROUDGTP Re: advice on tranny pan... 07-30-2009, 03:49 PM
Trannyman95 Re: advice on tranny pan... 07-30-2009, 07:40 PM
Liquifire Re: advice on tranny pan... 07-30-2009, 09:04 PM
gtpinsc Re: advice on tranny pan... 07-30-2009, 07:37 PM
Iron Indian Re: advice on tranny pan... 07-30-2009, 09:44 PM
Trannyman95 Re: advice on tranny pan... 07-30-2009, 11:45 PM
  1. #1 advice on tranny pan drop/filter change-trannyman?
    Wausau, WI
    I have a 98 GTP that I bought about a month ago with just over 100k on it. I am trying to go through it and change out some of the fluids and wanted to do a tranny pan drop and fluid refill(not flush) I have purchased the Amsoil ATF to go into the tranny as replacement fluid and was wondering if I should get a new GM tranny filter to go on there or what type of filter should I get. I just want a high quality one and not as concerned about price as long as it is not outrageous. Please give me advice on what type of filter I should be using. The vehicle is mostly stock except for a few bolt ons. Tranny is stock as far as I know. Thanks in advance..........
  1. (Solved) Trannyman Help! im in the middle of trans filter change.
    By speedemongtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2009, 02:30 PM
  2. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
  3. How long does it take to drop a tranny?
    By ohgreatone32 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2008, 01:38 PM
  4. Changing Flexplate - don't have to drop the tranny ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 12:56 PM
