hi all, well a month or so ago i had a whine after i flushed the trans ( should have just changed the filter and fluid ) well i was told then it could be the pump. i think trannyman hit the nail on the head! well after the whine ran its toll on the trans it started to quiet down,im thinking good right....no, it was the worst thing that could happen. i went about 20 miles got to my destination put the car in reverse and i knew i was in trouble. i put it in drive and still knew i was in trouble. i shut the car off. a little while later i got itn the car and put it in reverse and it seemed fine. then i waited about an hour and got in it to leave driving easy. no known problems except i knew the car didnt seem to have near as much power. i knew it was the trans. i stopped in the area a mile away and visited for aboiut 25 minutes then left, well when i got in the car this time i was crossing my fingers for home, i noticed a lil slip on start off, then i noticed it wasnt shifting out of second gear. so i knew not to drive on the freeway i took a road that speed was 40 m.p.h. once in a while it would shift into third, and then down to second, then it kind of stayed in third for a while ( 4th gear hub was stripped from previous owner ). i get a couple miles from home and there was a traffic back up so i stopped put it in neutral then traffic started to move and im not. i shut the car off for a few seconds, started it then drive and it caught, i pulled thru the alley, lost gear, shut it off, restarted it and it caught, basically i drove it home for about foru miles this way and made it. now all i have to do is leave the car idling for a few minutes and it will not move, restart it and it catches. i know i can hear something i assume with the pump. or something. I NEED HELP DETERMINING WHAT IS WRONG, AND IF THE TRANS CAN BE REPAIRED IN THE COR OR WHAT MY NEXT MOVE IS, I CANNOT EVEN FIND THIS TRANS ANYWHERE EXCEPT FOR SOMETHING OUT OF MY BUDGET. I AM MECHANICALLY INCLINED AND I HAVE CHANGED TRANNYS B4 ONE IN MY OLDER GRAND PRIX 3100. cap lock was on. i dont understand where the pump assembly is, is it like in the valve body or is it like behind the tourque converter???? any info will help. i do believe my clutches are fine in this trans, i always felt this car seemed "heavy" so somethingf is telling me to just scrap the tranny and get another one thats used..i dunno any ideas??? o and then i am told that only my year tranny will work. also i have a service manual for my old 93 gtp 3.4 dohc. its a 4t60e which is similar if i need any help.
