I just recently picked this car up and had no problems. I had the few hundred rpm shudder and found the fluid level was low..so i added a quart of lucas cuz it was pretty. All symptoms went away and I double checked the fluid which was still a little low so I added a little more. The next day it was totally jacked. It was slipping horribly. I couldnt even give it 25% throttle. It stalled on me twice on the way in and I had to turn it on and off on the way home. So I just pulled the codes and I have p741, 742 and 756. Which I already figured was the converter. ANy suggestions or help would be great. Thanks
