Thread: "Desert Fox" tranny cooler
Results 1 to 20 of 37
  1. #1 "Desert Fox" tranny cooler
    Jersey
    MotorSports Performance “Desert Fox” Transmission Cooler Kit: 3800 Performance
    Anyone have this cooler? Is it overkill? I want the best tranny cooler setup I can get, without it staying too cold. My temps stay constantly around 195*ish-over the 200*mark, with just normal driving in this Jersey heat. If i have my foot down the trans will heat up real quick, when i check the fluid, its bubbling on the stick.
    -Erik
    16' wrx sti- stock
  2. #2 Re: "Desert Fox" tranny cooler
    May 2008
    staten island,NY
    im looking at either that one, or the B&M supercooler with the fan on it. id like to have a fan on mine, especially with the t-stat in it so its not running 100% of the time
  3. #3 Re: "Desert Fox" tranny cooler
    TDCRacing
    Guest
    I'm sure I could put one together for you guys and start offering them on the site. I've been meaning to do that anyway. It would come standard with a fan and would also perform better than the desert fox in the cooling aspect.
    And it would be cheaper.
    It would more than likley also come with braided line and a secure way to attach it to the transmission line other than a hose clamp.
  4. #4 Re: "Desert Fox" tranny cooler
    Wausau, WI
    Quote Originally Posted by TDCRacing View Post
    That would be awesome.........I would definitely consider buying it from you if you had them to offer........
  5. #5 Re: "Desert Fox" tranny cooler
    TDCRacing
    Guest
    I'm going to try my hardest to have one put up for you guy's in the next week.
  6. #6 Re: "Desert Fox" tranny cooler
    Wausau, WI
    I won't be ready to buy that soon.......but I would like to see what you have to offer for a decent price.........keep up the good work
  7. #7 Re: "Desert Fox" tranny cooler
    TDCRacing
    Guest
    Quote Originally Posted by Liquifire View Post
    Well that's not a problem. I would just like to have them available for anyone who does want one when they want one.
    Thanks
  8. #8 Re: "Desert Fox" tranny cooler
    May 2008
    staten island,NY
    a t-stat and high quality fan would be great
  9. #9 Re: "Desert Fox" tranny cooler
    TDCRacing
    Guest
    In already have a very high quality fan that will not break tha bank sitting in the shop. Along with the test cooler. This was ment to be done a long time ago but never got it done.
    Anyway I'll have it done by sunday for sure.
  10. #10 Re: "Desert Fox" tranny cooler
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    If you plan to make a cooler make sure it is a good size! The ones I use and sell are 26K gvw rating and even a few guys need something larger than that because of mounting location, especially turbo guys that use a large front mount intercooler. Most people dont want to spend and arm and a leg either and if you go AN lines and fittings you can plan another $100 or more to the bill, then you still have the trans side fittings to work around and keep in mind that select years have a checkball in the feed cooler fitting that you CANNOT omit without internal changes. I looked into making kits for these cars a while back but there isnt much demand for them and not many people want to pay $200-$300 for a nice setup, and adding a fan and nice plug-n-play wiring bumps it up even more.
  11. #11 Re: "Desert Fox" tranny cooler
    TDCRacing
    Guest
    Hey Dave. We actually use the same Hayden coolers that you use
  12. #12 Re: "Desert Fox" tranny cooler
    Jersey
    well, if anyone cares I ordered the desert fox one
    16' wrx sti- stock
  13. #13 Re: "Desert Fox" tranny cooler
    Wausau, WI
    take install pics.................let us know how it goes as far as the install and how it works as far as how far tranny temps actually fall
  14. #14 Re: "Desert Fox" tranny cooler
    Fort Wayne, IN
    The Dessert Fox cooler is a very nice kit from the ones I have seen installed, Im sure you will be very pleased with it
  15. #15 Re: "Desert Fox" tranny cooler
    Jersey
    I will do
    Quote Originally Posted by Trannyman95 View Post
    I plan on using it with one of your built tranny's in the future
    16' wrx sti- stock
  16. #16 Re: "Desert Fox" tranny cooler
    Jersey
    Well my camera was dead, so i couldn't take any photos, sry. The install was a pita, holes didn't line up like they were supposed to on the cooler mounts, so i had to mod it a little. The hoses are well designed tho. I went on a 2 hour drive tonight to test out the tranny, my temps never got above 160", keep in mind it was a little cool tonight. Usually on a night like this i would see 175*. So far no leaks at all . I would recommend this cooler to anyone, just be prepared to shed some blood and tears on the install.
    Oh yeah and i smoked a mustang gt at a stop light on my test drive
    16' wrx sti- stock
  17. #17 Re: "Desert Fox" tranny cooler
    Moore, Oklahoma
    Just curious, did this cooler bypass the radiator cooler?
    Shawn W. Larsen
  18. #18 Re: "Desert Fox" tranny cooler
    Jersey
    Quote Originally Posted by Iron Indian View Post
    The return line on the factory rad/trans cooler was spliced using a/n fittings and barbs
    so fliud goes from trans--> rad--> desert-fox -->tranny
    16' wrx sti- stock
  19. #19 Re: "Desert Fox" tranny cooler
    Moore, Oklahoma
    I'd like to see install pictures once you do it. Thinking about getting one myself
    Shawn W. Larsen
  20. #20 Re: "Desert Fox" tranny cooler
    Jersey
    np, ill take some pictures once the camera is nice and charged up
    16' wrx sti- stock
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. question before i replace tranny "again"
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2009, 04:44 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
  4. Tranny "clicks" when I put it into gears and such...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-17-2008, 06:48 PM
