Thread: How much fluid do i need? Thanks
Results 1 to 20 of 21
  1. #1 How much fluid do i need? Thanks
    May 2008
    McHenry IL
    Hi guys car is on the meh side trans wise i feel the slip...... but figured hay i have NO cash so i might as well put a new filter and do a pan drop. how much fluid does it take to fill her back up guys for a pan drop?? thanks
  2. #2 Re: How much fluid do i need? Thanks
    Banned - Busted For Scamming
    Feb 2009
    if you can feel it slipping, leave it alone. changing the fluid is one of the worst things you could do right now
  3. #3 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    it takes more OMMPPHH to keep it accelerating and and the rpms seem to be higher then normal?
  4. #4 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    my trans doesnt shift hard or harsh though?
  5. #5 Re: How much fluid do i need? Thanks
    Feb 2009
    which gear/gears is it slipping in?
  6. #6 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    high so 3-4 but i just drove it around without performance shift on "i always keep it in performance shift" and without it in perf shift just now it shifts like showroom new soo crisp n clear but it has this sorta 1 to 2 second delay while shifting ?
  7. #7 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    but man she still has INSANE BALLS lol
  8. #8 Re: How much fluid do i need? Thanks
    Jersey
    HAHA! i can never understand you.
    worst case, start saving for a used trans
    16' wrx sti- stock
  9. #9 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    lol after a fluid filter change we will c wats upp
  10. #10 Re: How much fluid do i need? Thanks
    May 2008
    staten island,NY
    if you drop the pan i would say about 12 quarts. when my diff blew to pieces she took about 12 quarts. fill it with a few and keep checking. dont just dump 12 quarts in and walk away
  11. #11 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    yeah i know not to walk away and say DONE haha ive done that b4... i learned... lol thanks for the estimated number man props 2 you since u finally awnsered my main Q ha
  12. #12 Re: How much fluid do i need? Thanks
    Moore, Oklahoma
    12 quarts for a pan drop only?
    More like 8 quarts, at least thats what it is on my 99 and 00 GTPs.........
    Shawn W. Larsen
  13. #13 Re: How much fluid do i need? Thanks
    GTP Level Member Scimmia's Avatar
    QCA, IA
    GM spec is 7.4 qt for a pan drop and filter change, and that's been pretty close for me.
    2001 Buick Regal LS - Almost Stock
  14. #14 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    k thanks lol
  15. #15 Re: How much fluid do i need? Thanks
    Wausau, WI
    I would think eight as well..........you should have some left in your converter....fwiw
  16. #16 Re: How much fluid do i need? Thanks
    Feb 2009
    The reason why i did not answer your question is because if you are already slipping now, changing your fluid is going to do nothing for you but make it worse, maybe even not be able to be driven. Your best bet if its slipping for sure is to just let it ride until a rebuild.
  17. #17 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    you guys think thats what i should do? can it ever get better? it only slips in 3 and 4th is there any additives or w.e to make it better? =[ lol
  18. #18 Re: How much fluid do i need? Thanks
    May 2008
    McHenry IL
    cuz hnestly i have NO cash and i need a battery soon mine is sulfided =[ and a pain in the ass to start sometimes so battery is first..... and yeah im a poor college kid that needs my gtp so what is my best bet guys? change out the filter n fluid and maybe ad some additive and see what happeens?
  19. #19 Re: How much fluid do i need? Thanks
    el paso
    i'd go with the 7 quarts! thats how much my car needs. 97 gp
  20. #20 Re: How much fluid do i need? Thanks
    Jersey
    "additives" are full of fail...
    16' wrx sti- stock
  1. Fluid
    By BwolfGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2009, 11:11 PM
  2. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
  3. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
  4. Windshield fluid doesn't come out
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 12-02-2008, 02:29 PM
  5. How much fluid does the s/c take?
    By brodyman in forum General Tech Discussion
    Last Post: 09-17-2008, 02:15 PM
