Thread: trans coolier/shift problem
Results 1 to 15 of 15
Threaded View
  1. #1 trans coolier/shift problem
    Feb 2010
    Flint Michigan
    i am using this trans coolier on my 1998 gtp.
    Hayden Automotive 678 - Hayden Fluid Coolers - Overview - SummitRacing.com
    not sure if the problem was there when i first installed the trans cooler.
    but now i have noticed my trans shifts high, 3 grand each gear when I am just cruising around town. is this normal?
    could the trans coolier be causing this?
    could the trans be to cold and torque lock up not working?
    could drit or grit in trans from having 190,000 miles maybe clogging up trans cooler, increasing presser, and restricting flow?
    could torque converter be going out?
    could trans just be going out?
    also if i floor it WOT it shifts at 5700, is this normal?
    need some feeback dont want to rip off the cooler if thats not the problem.
  1. GTP Trans won't shift to 4th after hill
    By SliceTheRice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-11-2010, 10:37 AM
  2. Trans does not want to shift out of 1st until warm
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 11:45 AM
  3. What Trans Shift Points should I use?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-25-2008, 08:04 PM
  4. shift kit problem.
    By 00pontiac1971 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2008, 06:47 PM
  5. Does the trans need to be dropped to swap out shift solenoids?
    By bminior in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-08-2008, 08:59 AM
